Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Perguntas Visualizar todos
My playstation 3 is stuck 99% while updating!
I have to update my playstation (Update 4.10) i have updated it, and it freezes at 99 and i wait for it, it says i have error code 8002f310. I'm too young to know anything about that, but if i send it to sony, do i pay online ?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
My PS3 says the system could not be run correctly so I got my usb PS3>UPDATE>then the download. It recognised the the file and said install update 4.80 or later. after 30min it said it is taking longer to install and got stuck on 99%. The same message came up again. Please help me I don't want to lose any memory or data on it.
por
Adicionar um comentário
3 respostas
Solução escolhida
I got good news and bad news. The best thing you can do is download the patch on your PC. Take a USB stick and format that as FAT32. Created a directory called PS3 and then a directory in there called UPDATE. Throw the downloaded patch in that directory which will now allow you to update teh PS3 without downloading the file from the internet. Thats the good news.
On the bad side, you have to take the drive out of your PS3 and format it on a computer so that the PS3 no longer recognizes it as a valid drive for it. Once that is done then you just pop it back into your PS3 along with teh USB stick in the port and follow the on-screen instructions. That will fix your console up and proceed through the update without issues.
I have had three of those type of systems come through my door in the past week. I charge $30 to get it out of the loop doing exactly as I just described.
Good luck!
Esta resposta foi útil?
Pontuação 1
2 comentários:
Do you lose your data and saved games if you follow the above process?Please answer it is important?
por
When you format the drive under Windows, do you make it NTFS or ExFAT?
por
My solution is I have restarted the PS3 which was stuck at 99% for almost 10 time, while trying to enter in into Safemode. However before restarting I removed the HDD once and did the hardreset multiple time and the systems moved from 99% to 100 and rebooted automatically.
Pontuação 0
3 comentários:
What is HDD? The Harddrive?
por
@Tanner McPherson yes
por
you removed the HDD while update was in progress? can you give exact steps?
por
I am having the same problem. I am essentially brain dead due to a traumatic brain injury. I cannot fix this myself. I want my ps3 back. Can anyone help?
Pontuação 0
Adicionar a sua resposta
soummv será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 46
Últimos 30 dias: 206
Duração total: 26,754
