No Network Signal but finds carriers, Blue coil?
Hi,
My Iphone 4 doesn't connect to any network... Is says "Searching" and then goes to "No Signal".
If I go to "Carrier" in settings and disable the "Automatic" option it finds all the available networks in range...
I've looked everywhere for a solution and I the only one that I've found that may relate to my problem is the blue coil solding but before I try this solution I wanted to be sure that It may be my problem...
Because no one that says that the problem with their phone was the blue coil talks about the phone being able to list the carriers... The other thing is that I have normal wifi connection...
Can anyone help me? Do I really need to fix the blue coil?
Thanks in advance
Esta é uma boa pergunta?
2 comentários
Hi Daniel,
Have you found an answer to this yet? I'm having the exact same problem.
Plz let me know when you have found the solution!
Thanks,
Nick
por Nick Dalewood
Hi Nick,
Unfortunatly I haven't found a solution still... I've ordered some parts and I'm waiting for them...
If the parts doesn't fix my problem I will try the blue coil jump and I'll post here the results...
por Daniel Alves
