Stuck disc problem: Disc gets stuck in limbo if it doesn't mount
When I insert a disc it's iffy if the disc will mount.
If it does go in and mount, the disc normally works fine and is recognized, etc. so it doesn't seem that the superdrive itself is broken.
However, increasingly, the disc won't move into proper place and the computer doesn't recognize it has having been inserted. I can't actually see what's going on, but it seems like it's getting stuck halfway.
If it doesn't mount and isn't recognized, I usually have to do the eject command in terminal. This normally requires repeated tries and eventually a tiny bit of the disc pokes out of the slot and I can get ahold of it and pull it out. So far, none of the discs that this has happened with is damaged.
Pretty much, I just avoid inserting discs and I feel like an external drive would be easier. It seems like something is bent or catching though, and I wonder if anybody else has this specific problem.
Suggestions? Thanks for any info.
Esta é uma boa pergunta?
