Ir para o conteúdo principal
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
528 Perguntas Visualizar todos
Where to find Start up disk or Recovery Disk.
It seems my MAC OS is corrupted cause when the iBook start up it display a question mark "?" after the chime and apple logo. I tried to re-install or use the PowerBook G4 15" recovery disk but it wont continue... it freeze the system and display huge white horizontal line after chime and apple logo. i really need help.. thankss
Esta pergunta é pertinente?
Pontuação -1
Adicionar um comentário
1 Resposta
Solução escolhida
The question mark means that your iBook can't find a system folder. Most likely a bad hard drive. When you tried the"recovery disk" did you start up holding the "C" key down? What is this Recovery Disk? To check the computer out, you can start it in Target Mode by connecting it to another Mac via firewire cable and start the iBook up holding the "T" key down. You can then try to run disk utilities on it.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Cled Tayamen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,765
