Ir para o conteúdo principal
Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
194 Perguntas Visualizar todos
Why has my screen changed to black and white
For some reason the playstation 2 is in black and white only. We tried to plug something else into the connection on the TV and it was fine but the playstation is still only black and white.
Esta é uma boa pergunta?
Pontuação 10
6 comentários
i have a similar problem with my ps2, however I bought a aftermarket cable, would this cause it to show black and white?
por
after playing game for sometime by pendrive graphics become un-understandable why???
por
Thanks a bunch, it works!
por
I have this problem, but I have the slim version, is there a difference? and I have a weird tv, that does not have the normal yellow, white and red holes for the cables, but video works, and sound just fine, but no color.
por
Everytime i play f1 2006, richard burns rally, and a few other game on my ps2 my tv screen just black and white but if i play other games like gran turismo 4 original japan, and nfs underground 2 it has colours.
por
Exibir mais 1 comentário
Adicionar um comentário
4 respostas
Solução escolhida
Tara, depends on how you have your PS2 connected. If you are using the component cables, check in the system settings and check if its in regular RGB. If you use the regular Yellow, Red and White cables, it should be in RGB mode.
Esta resposta foi útil?
Pontuação 3
8 comentários:
this didnt help me but my PS2 is in RGB mode already
por
Is ur ps2 modded
por
Now it won't let me view system settings it will only play movies n is still in black and white now I can't change it back from RGB that what's it normally was
por
i needed to change my tv to the AV channel instead of the component channel also to fully fix this issue
por
Thank you halo117ish
por
Exibir mais 3 comentários
Pergunta mais útil
I was having the same problem but I changed my input from component to AV and that worked.
Pontuação 11
14 comentários:
I did exactly what you said and it works! Tq tq tq
por
Me too!!! Thanks a bunch! Putting on AV worked :D
por
Thanks a bunch, it worked!
por
How can i change my input to av ?
por
Just go to input it should be right on your remote for the TV and then you should see AV as one of the options then push the up or down arrow to go to the AV option the once you are on it the push select that's the button that says select on it yeah you just push that button.Thats it.
por
Exibir mais 9 comentários
This one is problem on the HDTV with tons of features in it. First go to your TV's settings and open option (in my case I'm using 50" Sharp Aquos 1080p), if you don't find it check something similar to above. Then, you want to change the "Input Select" from "Component" to "Video." This will change the color system automatically as "Component" label are for newer devices and sometimes can't cope with older devices such as PS2. After you've done it you might see the "Colour System" option and that's where colour calibration option exist. My TV sets itself to NTSC 3.58 where as the component shows 480i(with monochrome color).
Pontuação 3
3 comentários:
Thank you this helped a lot
por
That was exactly what fixed my issue.
thank you!!
por
Omg thanks so much
por
My tv is sony how can do this
Pontuação 0
1 comentário:
I have a samsung q60t qled tv and switching between sources of hdmi to av via the menu system, the colour came back
por
Adicionar a sua resposta
Tara será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 43
Últimos 7 dias: 276
Últimos 30 dias: 1,324
Duração total: 239,497
