ring behind security slot broke
The detent ring behind the security slot broke. I am unable to use a security cable now, it pulls right out.
Esta é uma boa pergunta?
I'm look at one right now and I don't see a ring. What type of locking cable are you using? This is part of the bottom case and not separate so you would need to replace it. Here's the part: [produto vinculado ausente ou desativado: IF155-013]
Here's how it's done: PowerBook G4 Aluminum 17" 1-1.67 GHz Heat Sink & Fan Assembly Replacement
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 611
1 comentário
I noticed you never got an answer to this. Are you still having this problem
por originalmachead
