iPhone motherboard is damaged by water
how can i fix my iphone shopkeeper said its motherboard is damaged how can i fix it now??? can you help me???
Esta é uma boa pergunta?
Saira Hafeez, the first thing you want to is to clean your phone. It sounds from your question like the damage is already a bit older. Rice, or any other remedy, will only help in an acute phase. It will only displace some of the water, and will not prevent corrosion. You never want to turn on any device that has had water damage until it is properly cleaned, turning it on may cause short circuits due to corrosion. Follow this guideto clean your phone. It was written for a 3G but all the points still apply to your phone as well. Once you cleaned is properly,'replace the battery and reevaluate for any damage.
Esta resposta foi útil?
Do not put it on rice.. even if it sucks the water out you will still have corrosion because of the minerals the water contains. I dont know why people always say rice, doesnt make a difference. Anyways try a full water damage treatment with an ultrasonic cleaner and that should do the trick. Hope this helped
Well first off.. what is the problem with your phone? The best thing you can do right now to prevent further damage is shove it in a bag of rice to let it soak up the water to prevent as much corrosion as possible.
After 6 hours of hanging out in rice, see whats wrong with the phone.
Is it turning on?
Is the back light dim?
etc.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,499
