got the error code, it's 0011
Okay so I did what he said, got the error code, it's 0011, what should I do, if it needs professional repairs where do I take it and roughly how much would it set me back?
-MH
Esta é uma boa pergunta?
-MH
MH, 0011 means CPU is overheating. It can also mean that there was some damage to the CPU or GPU from intentionally overheating it (aka towel trick, stopping the fan, the baking trick, etc.)
If this is the case, then there's no fix for it.
A professional reflow can set you back at around $40-50. It might not be worth it. If you do decide to take it to a professional, make sure they are using a real rework machine, not a heatgun/paintstripper or a cheap reflow station with a pancake griddle.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 664
