Pular para o conteúdo principal
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1961 Perguntas Ver todas
3GS turns off at ~60%
My 3GS turns off at appx. 60 % - Will power on again only when charger connected.
In diagnose log following error is displayed:
Reset count:0
Boot failure count:1
Boot faults: rst vdd_under
Boot stage: 80
Boot app: 0
Is this causer by bad battery or?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
kits de reparo de baterias de iPhone
Only $29.99
Buy Now
Only $29.99
Buy Now
3 Soluções
Resposta Mais Útil
I have changed many batterys that die at higher percentages than you would think. Best solution is to purchase a battery and follow the guide here on ifixit to install, or find someone who can help you out. This will resolve your issue 99/100 times.
Esta resposta foi útil?
Pontuação 1
This would in fact be the cause of a bad battery.
Pontuação 0
Same problem for me with my iphone 4, but just reset or keep the screen black until push the on/off button to turn on but not ask for pin code....:
Diagnose log error:
Reset count:0
Boot stage: 255
Boot app: 0
Is this causer by bad battery too?
Thanks in advance.
Pontuação 0
Adicionar a sua resposta
reenee será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 3,316
