Internal sound not working.
I have tried everything but im having no joy. Sound plays ok through headphones but soon as i unplug them I get NO sound coming from the built in internal speakers.
Please Help.
Big Thanks
Esta é uma boa pergunta?
Please Help.
Big Thanks
Could you boot the MacBook from an external source to verify if the problem is hardware or software issue ? Check the headphones port with a flashlight. What is the system preferences -> sound panel -> output status ? Also, repairing permissions can sometimes fix a sound problem.
Esta resposta foi útil?
Beat me by 27 seconds--+1 for a good answer. Ralph
Two possibilities come to mind. 1. The speaker connection to the logic board is faulty or 2. the headphone jack has a problem and is not connecting the speakers when you remove the headphones. You can try looking at the jack without removing the top cover but I suspect you will need to take it apart. Ralph
Could be a broken tip on the audio jack. +vote for the good "late" answer
With a broken tip inside the sound port the OP would have no heaphones sound and he says that << sound plays ok through headphones>>.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 896
1 comentário
third time you asked the same question in 7 hours
por mayer
