battery out majured 3,164v instead of 3,7v...
so replaced it ?!
Esta é uma boa pergunta?
so replaced it ?!
jef, all those errors could most certainly be caused by a bad battery. It is possible that your battery is no longer holding a charge. The voltage is not a good indicator of the overall condition of the battery. I would start by replacing the battery. Hope this helps, good luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 371
2 comentários
Please give us more details on what is going on. Are you asking whether or not you should replace it? Did you have a problem in replacing it? What's your battery life like? The more we know, the better we can help you.
por Adam Hintz
well,
it my iPhone started to have problems it would shut down hard when it was fully charged. then it was difficult to reboot the phone. but when i plugged it in it charged. but it on again and after 30min or so it shuted down again.
all programs and buttons were working when it worked it did what it had to do.
Now it didn't do anything.
i confirmed that the charging unit was good with another iPhone.
i tried the start up with the home and power button for 10 sec.
but it stays death
As i was told i would get mutch store credit i was going to solve the problem myself. though as the phone works fine when its charged it has to be a battery or loading dock problem.
but before spending money on ordering new battery or docking piece i was looking for some input...
thanks a lot
por jef
