<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;iPad Pro 11&quot; 4th Gen&quot;]]></title>
<link>https://pt.ifixit.com/Answers/Device/iPad_Pro_11%22_4th_Gen?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;iPad Pro 11&quot; 4th Gen&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 10 Aug 2026 13:39:11 -0700</pubDate>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Reoccuring Panic Full Crash - Resolves a bit when Pressure on Screen]]></title>
<description><![CDATA[<p>I've had a screen replacement done recently after a semi full can fell on my iPad screen (on the area above the charging port)/<br /><br />Information regarding the issue:<br />- If left alone, it will flash a purple screen (sometimes, not always), crash, then reboot and indicate that it has 0% battery left when it is not empty.</p>
<p>- It will restart around every 3 minutes.<br />- When pressure is applied on the screen area above the charging port, the battery indicator returns to normal and the crashing halts.</p>
<p>- When pressure has been applied on that area of the screen for a while, it will stay alive for much longer than 3 minutes (it lasted an hour last night).<br /><br /><br />I do intend on taking it to the repair shop ASAP but could anyone potentially tell me what the problem is?<br /><br /><br />&quot;panicString&quot; : &quot;panic(cpu 0 caller 0xfffffe00109bdf40): SMC PANIC - ASSERTION FAILED: target\/j61x\/target.cpp:365: 0, SMC BSC failure, spreadsheet ver(*10) 351801\nS.sensor array 0 - 6 is 0x5b, 0x2000, 0x0, 0x0, 0x0, 0x0, 0x0\n\n - Misc(2) OUTBOX2 not ready\nASSERTION FAILED: target\/j61x\/target.cpp:365: 0, SMC BSC failure, spreadsheet ver(*10) 351801\nS.sensor array 0 - 6 is 0x5b, 0x2000, 0x0, 0x0, 0x0, 0x0, 0x0\n\n\nRTKit: RTKit-2413.60.9.release - Client:<br /><br />This is a snippet of the panic full crash log.</p>
<p>⟐ Answered agosto 28, 2025 at 8:17 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/833138/Reoccuring+Panic+Full+Crash+-+Resolves+a+bit+when+Pressure+on+Screen</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/833138</guid>
<pubDate>Thu, 28 Aug 2025 08:17:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Battery Replacement and Adhesive Strips]]></title>
<description><![CDATA[<p>After four long years of use the battery on my iPad Pro is lasting less and less time. I am thinking about replacing the battery. Looking at the repair manual for the third generation which uses the same battery I have two questions. Can I use the same manual? or should I use the screen replacement manual for the appropriate parts on the actual manual, that is, generation 4 and substitute the third for what is appropriate? My main question is replacing the Adhesive strips for mine. It is not even mentioned in the third manual and they are $170 for my model. Why are these so expensive. Are they needed for battery replacement? I want to do an excellent job, but that price is way out of line compared to other models. What's up? Thanks for the help.</p>
<p>⟐ Commented maio 12, 2026 at 17:29 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/954113/Battery+Replacement+and+Adhesive+Strips</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/954113</guid>
<pubDate>Tue, 12 May 2026 17:29:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: iPad Pro 11" 2022 does not charge. The connector has been replaced.]]></title>
<description><![CDATA[<p>The iPad periodically did not charge and stopped charging at all. I disassembled it and charged the internal battery. The iPad turned on and works fine except for charging and data transfer via cable. I replaced the connector. I examined the old one carefully and I do not rule out that the contacts on it were damaged and shorted out. With the new connector, the iPad also does not want to charge. I checked the USB-C tester and I see that the VBUS line is faulty, but I do not have a diagram to trace the path of this line and decide on further repairs.</p>
<p>Voltage on the port is 5V, current fluctuates around 0.2A.</p>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="VBtVTmDWBDrGPoBI" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/LnUihhTMXcJnXjcx.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/VBtVTmDWBDrGPoBI_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<p>Perhaps someone has a diagram of at least previous models to suggest where to look for the problem? Can you advise anything?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/VdQK3lrY3cYY1weS.standard" width="169" height="225" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/VdQK3lrY3cYY1weS.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>Thanks!</p>
<p>⟐ Commented abril 08, 2026 at 22:45 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/865624/iPad+Pro+11%22+2022+does+not+charge.+The+connector+has+been+replaced.</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/865624</guid>
<pubDate>Wed, 08 Apr 2026 22:45:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Does this use the same screen as the 2021 11 inch pro?]]></title>
<description><![CDATA[<p>Thinking if I should get one, want lcd screen with no PWM, after learning that 2020 iPad Pro uses pwm on their LCD screen, I became concerned about the screen dimming method that the latest iPad uses</p>
<p>⟐ Answered dezembro 07, 2022 at 8:40 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/753145/Does+this+use+the+same+screen+as+the+2021+11+inch+pro</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/753145</guid>
<pubDate>Wed, 07 Dec 2022 08:40:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Ipad got wet, screen very dim but fully functional]]></title>
<description><![CDATA[<p>Hi, I had an extremely unfortunate incident of a zero sugar monster energy can exploding in my backpack while travelling, i dried my ipad off as much as i could but when i arrived at my destination i discovered that the screen was very dim. The face ID also doesnt work. The screen otherwise responds normally, i put it in some rice overnight but i havent had any success so far. Am I done for :(? I really hope it can be fixed</p>
<p>Thank you for anyone who can help!!!</p>
<p>⟐ Commented março 25, 2024 at 14:14 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/842256/Ipad+got+wet,+screen+very+dim+but+fully+functional</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/842256</guid>
<pubDate>Mon, 25 Mar 2024 14:14:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Brought from an Auction, my iPad is icloud locked, what to do?]]></title>
<description><![CDATA[<p>I recently brought an ipad from an auction with all the receipts and VAT applicable. Unfortunately, I am not hearing back from the support cases I raised to apple to unlock it, I understand I can't do much with it now but are there any possible solutions, except to sell it for parts?</p>
<p>⟐ Commented março 05, 2026 at 4:44 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/943074/Brought+from+an+Auction,+my+iPad+is+icloud+locked,+what+to+do</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/943074</guid>
<pubDate>Thu, 05 Mar 2026 04:44:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Cant find local australian stock for screen replacement A2759 iPad pro]]></title>
<description><![CDATA[<p>Any pointers on where to find local stock (Victoria, Aus) for iPad pro 4th Gen 11&quot; ? Model A2759</p>
<p>These are in stock at US storefront, but in addition to the listed price, there would be shipping costs and then it has to go through customs clearance and pay custom duty etc. Whats the alternative?</p>
<p>⟐ Answered março 03, 2026 at 5:10 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/943049/Cant+find+local+australian+stock+for+screen+replacement+A2759+iPad+pro</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/943049</guid>
<pubDate>Tue, 03 Mar 2026 05:10:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Help help help need help asap]]></title>
<description><![CDATA[<p>First question is one of the proximity sensors when I did the screen repair broke is there anything I can do to fix it second thing is now that I have everything back together. It’ll connect to the Wi-Fi but it’ll say that there’s no Wi-Fi connection.</p>
<p>⟐ Answered julho 01, 2025 at 10:52 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/905730/Help+help+help+need+help+asap</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/905730</guid>
<pubDate>Tue, 01 Jul 2025 10:52:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Does anyone have a source for a rear housing?]]></title>
<description><![CDATA[<p>I have come across one of these iPads for pretty cheap, in a pretty damaged condition. iPad does appear to work and with the logic board being located in the center so I am not too concerned aboutThe ability to fix or have any unfixable damage. The rear housing is absolutely destroyed on one side with it being caved in with warps in the aluminum being akin to a pug dogs face, and the other side being extremely bent so there is no beating the dents out, replacement is the only option. Displays are easy enough to come by but the actual housing seems nearly impossible. Even have checked the likes of Aliexpress and either I am using the wrong search terms or they aren’t available there either. If anyone has any source that would be much appreciated. Thank you in advance.</p>
<p>⟐ Commented maio 06, 2024 at 13:19 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/848490/Does+anyone+have+a+source+for+a+rear+housing</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/848490</guid>
<pubDate>Mon, 06 May 2024 13:19:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Does this use the same battery as the 3rd Gen?]]></title>
<description><![CDATA[<p>Does the iPad Pro 11&quot; 4th Gen use the same battery as the iPad Pro 11&quot; 3rd Gen?</p>
<p>⟐ Answered abril 19, 2024 at 14:54 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/845962/Does+this+use+the+same+battery+as+the+3rd+Gen</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/845962</guid>
<pubDate>Fri, 19 Apr 2024 14:54:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: trying to find a PMICS chip 343s00477 ao]]></title>
<description><![CDATA[<p>I have a iPad Pro 11&quot; model A2759 3 years old . I can't seem to find the 343s00477 ao chip ? Does anyone have any suggestions?Well If MR fixit can't fix it then no one can .</p>
<p>⟐ Edited by author outubro 06, 2025 at 8:47 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/920214/trying+to+find+a+PMICS+chip+343s00477+ao</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/920214</guid>
<pubDate>Mon, 06 Oct 2025 08:47:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Why did my ipad shut off and when I turn it on it only has the apple s]]></title>
<description><![CDATA[<p>Only has the apple logo</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/913754/Why+did+my+ipad+shut+off+and+when+I+turn+it+on+it+only+has+the+apple+s</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/913754</guid>
<pubDate>Sun, 24 Aug 2025 16:29:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Has anyone had isseues with the volume buttons]]></title>
<description><![CDATA[<p>Hello, i have an A2435 ipad pro 4th Gen. It seems like my volume down button is stuck. The volume level automatically and randomly lowers it self. I have not been able to find any guides for repairs for that.</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/903943/Has+anyone+had+isseues+with+the+volume+buttons</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/903943</guid>
<pubDate>Mon, 16 Jun 2025 08:27:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Reocurring iPadOS Kernel Panic]]></title>
<description><![CDATA[<p>Having this issue with my iPad Air M1.</p>
<p>{&quot;bug_type&quot;:&quot;210&quot;,&quot;timestamp&quot;:&quot;2024-12-27 15:45:03.00 +0100&quot;,&quot;os_version&quot;:&quot;iPhone OS 18.2 (22C152)&quot;,&quot;roots_installed&quot;:0,&quot;incident_id&quot;:&quot;1A9F302E-041A-411B-A477-8F2F8E9C0F46&quot;}</p>
<p>{</p>
<p>&quot;build&quot; : &quot;iPhone OS 18.2 (22C152)&quot;,</p>
<p>&quot;product&quot; : &quot;iPad13,17&quot;,</p>
<p>&quot;socId&quot; : &quot;8103&quot;,</p>
<p>&quot;socRevision&quot; : &quot;11&quot;,</p>
<p>&quot;incident&quot; : &quot;1A9F302E-041A-411B-A477-8F2F8E9C0F46&quot;,</p>
<p>&quot;crashReporterKey&quot; : &quot;97fd4c732fc6f49b06d9eb5fd8c8dbd91aaa8d92&quot;,</p>
<p>&quot;kernel&quot; : &quot;Darwin Kernel Version 24.2.0: Thu Nov 14 22:51:23 PST 2024; root:xnu-11215.62.3~1\/RELEASE_ARM64_T8103&quot;,</p>
<p>&quot;date&quot; : &quot;2024-12-27 15:45:03.32 +0100&quot;,</p>
<p>&quot;panicString&quot; : &quot;panic(cpu 3 caller 0xfffffe0026a9c294): SMC PANIC - ASSERT: target\/ipad13b\/target.cpp:342: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 7 is 0x2000, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0 0x0\nF.sensor array 0 - 1 is 0x0 0x0\n\n - Misc(2) OUTBOX2 not ready\nASSERT: target\/ipad13b\/target.cpp:342: 0, SMC BSC failure, spreadsheet ver(*10) 40\nS.sensor array 0 - 7 is 0x2000, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0 0x0\nF.sensor array 0 - 1 is 0x0 0x0\n\n\nRTKit: RTKit-2758.60.101.release - Client: AppleSMCFirmware_H13-5204.60.266.ipad13b.REL\n!UUID: 2d95f501-5706-3253-ba49-ad822112ce4c\nASLR slide: 0x0000000000000000\nTime: 0x000000041fc68423\n\nFaulting task   2 Call Stack: 0x0000000000034ac0 0x0000000000034450 0x000000000003426c 0x0000000000032cb0 0x000000000002d8a8 0x00000000000230ac 0x0000000000027de4 0x0000000000030600 000000000000000000\n\nChinook ASC Async error info: \nl2c_err_sts 0x5000fbfc00000000, l2c_err_adr 000000000000000000, l2c_err_inf 000000000000000000\nlsu_err_sts 000000000000000000, fed_err_sts 000000000000000000, mmu_err_sts 000000000000000000\ndpc_err_sts 000000000000000000\n\nMailbox (0): (0)\n  Inbox  AKF_KIC_INBOX_CTRL = 0x00020001, AKF_KIC_MAILBOX_SET = 0x11111101\n  Outbox AKF_AP_OUTBOX_CTRL = 0x00020001, AKF_AP_MAILBOX_SET  = 0x00000000\n\n    dir   endpoint      timestamp           msg</p>
<p>⟐ Commented março 22, 2025 at 17:09 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/892626/Reocurring+iPadOS+Kernel+Panic</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/892626</guid>
<pubDate>Sat, 22 Mar 2025 17:09:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Ipad Pro a2759 Screen Replacemente Compatibility]]></title>
<description><![CDATA[<p>Hello,  i have an Ipad A2759  need the screen replacement.<br /><br />This is Compatible? <br /><br />Item # IF323-070-1</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/869874/Ipad+Pro+a2759+Screen+Replacemente+Compatibility</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/869874</guid>
<pubDate>Tue, 17 Sep 2024 11:07:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: Ipad not charging needs a Chip replacement]]></title>
<description><![CDATA[<p>Hello, good evening</p>
<p>My iPad Pro 11 inch 4th generation (2022) has unfortunately broken and no longer charges. I took it to Apple but they didn't want to repair it but wanted to buy a new one but unfortunately I can't afford that.</p>
<p>I took the iPad to a repair technician to try to repair it. He told me that the charging port and battery are not the problem but a charging chip and he gave me the serial number and told me to look for it, find it and bring it here so that the iPad can be repaired.</p>
<p>POFUV300A1</p>
<p>I think its an IC charging chip</p>
<p>I need help, please.</p>
<p>saadi</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/855369/Ipad+not+charging+needs+a+Chip+replacement</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/855369</guid>
<pubDate>Tue, 18 Jun 2024 14:53:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: iPad Pro panic full crash two times]]></title>
<description><![CDATA[<p>I have a problem with my iPad. my you guys have the answer what caused the issue, it freezes on the lock screen after waking up the device. This has happened twice in just 6 days. The panic full log shows the same problem like this.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/1ZJEuO1ZekLVUuYT.standard" width="282" height="70" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/1ZJEuO1ZekLVUuYT.full&quot;, '', 'width=1516,height=376')" /></div>]]></description>
<link>https://pt.ifixit.com/Answers/View/847263/iPad+Pro+panic+full+crash+two+times</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/847263</guid>
<pubDate>Sat, 27 Apr 2024 10:30:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[iPad Pro 11" 4th Gen: How to change volume buttons cable]]></title>
<description><![CDATA[<p>Hi. I have damaged volume buttons cable, but I don’t understand, where it’s connected to motherboard. Thanks.</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/826916/How+to+change+volume+buttons+cable</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/826916</guid>
<pubDate>Mon, 04 Dec 2023 12:09:06 -0700</pubDate>
</item>
</channel>
</rss>
