<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Water Heater&quot;]]></title>
<link>https://pt.ifixit.com/Answers/Device/Water_Heater/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Water Heater&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 06 Aug 2026 10:15:58 -0700</pubDate>
<item>
<title><![CDATA[Water Heater: Water heater not heating - RESOLVED]]></title>
<description><![CDATA[<p>We have a GSW 3000W water heater which is not heating the water at all.</p>
<p>I checked some answers here and went through some checks.</p>
<p>We get power to both screws on both upper &amp; lower elements.</p>
<p>I checked both elements for resistance and got readings of 19.6 on both.</p>
<p>I checked the resistance of the upper element, screws to heater body and no indication of resistance.</p>
<p>I have replaced the upper thermostat.</p>
<p>What else could be the problem?</p>
<p>Thank you,</p>
<p>Dave</p>
<p>⟐ Answered julho 03, 2026 at 21:52 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/780667/Water+heater+not+heating+-+RESOLVED</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/780667</guid>
<pubDate>Fri, 03 Jul 2026 21:52:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Ariston Boiler Turning On and Off Repeatedly + Yellow Warning Light]]></title>
<description><![CDATA[<p>Hi everyone. I have an Ariston boiler/water heater and I’m having an issue with it.</p>
<p>It turns on normally, heats the water for a short time, then shuts off. After a while, it turns on again. The water keeps alternating between hot and cold.</p>
<p>There is also a yellow/orange warning light on the control panel (photo attached). I already tried pressing the “Reset” button, but the problem continues.</p>
<p>Does anyone know what could be causing this? Could it be low pressure, a faulty sensor, limescale buildup, or another common issue with this model?</p>
<p>Thanks in advance.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/JLIngdLHHS1E2dnP.standard" width="169" height="225" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/JLIngdLHHS1E2dnP.full&quot;, '', 'width=1152,height=1536')" /></div>
<p>⟐ Commented maio 28, 2026 at 1:57 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/956486/Ariston+Boiler+Turning+On+and+Off+Repeatedly+++Yellow+Warning+Light</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/956486</guid>
<pubDate>Thu, 28 May 2026 01:57:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: no power in lower element?]]></title>
<description><![CDATA[<p>I can't seem to get power to the lower element of my electric hot water heater the top one reads fine but the bottom one does not</p>
<p>⟐ Commented maio 19, 2026 at 14:05 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/317420/no+power+in+lower+element</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/317420</guid>
<pubDate>Tue, 19 May 2026 14:05:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: How is the unit supposed to be wired to prevent overheating at connect]]></title>
<description><![CDATA[<p>The Rheem Essentials on-demand electric water heater (240v, 13kW) that I have does not come with a clear diagram or instructions for wiring properly to install it correctly, not in the owners manual nor is it available online, that I can find. Using the recommended 1x6 AWG wire and 60 AMP dedicated breaker, which wires get connected to which inside the unit to power which system functions? Outside of green to green for ground, instructions say only to &quot;connect the wires&quot;... Where do you connect specifically the red, black, and white wires?</p>
<p>⟐ Commented fevereiro 19, 2026 at 1:22 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/941024/How+is+the+unit+supposed+to+be+wired+to+prevent+overheating+at+connect</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/941024</guid>
<pubDate>Thu, 19 Feb 2026 01:22:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[CALENTADOR JUNKERS WR11-2: How do I fix the oven on this heater?]]></title>
<description><![CDATA[<p>The candle is working but the heater's oven won't light.</p>
<p>⟐ Commented janeiro 30, 2026 at 5:58 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/915633/How+do+I+fix+the+oven+on+this+heater</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/915633</guid>
<pubDate>Fri, 30 Jan 2026 05:58:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Richmond electric ECO water heater not heating - RESOLVED]]></title>
<description><![CDATA[<p>I have a Richmond 12E50-DEC 50 gallon water heater which has digital controls in which after powering off/on with the circuit breaker can be set to heat, but oly powers the upper electric element fo around 1 minute, then the digital control disables the voltage to the heater element.  Lower element never gets voltage applied.</p>
<p>Both elements are both 11.5 ohms and appear to be good.  Am attempting to remove and measure the thermocouple but using the digital diagnostic, I observe lower on at 54 F and upper at 77F, so are somewhat reasonable values for a tank that was at room temperature and then had some water come in from the well into the lower chamber.</p>
<p>I understand that these controls me only turn on one heater element at a time which would explain the upper element getting voltage for 30 seconds or a minute but then unclear why the control with turn off the heat without posting any kind of error code as there are no codes in the history.</p>
<p>Any help would be appreciated.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_11_27_Num_2022" class="header">Update (11/27/2022)</h3></div>
<p>Called Richmond (Rheam) customer service.The representative felt this was likely a faulty digital circuit board since no error codes were being posted in the history and due to the behavior observed where the upper element was powered for about a minute after a power cycling off/on using the circuit breaker. Service person advised me that the upper heater element would normally be powered for about 20 minutes before switching power to the lower heater element.</p>
<p>New circuit board being sent free of charge under the 12 year parts warranty.</p>
<p>⟐ Commented dezembro 14, 2025 at 10:35 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/757340/Richmond+electric+ECO+water+heater+not+heating+-+RESOLVED</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/757340</guid>
<pubDate>Sun, 14 Dec 2025 10:35:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: tabodd 16l gas water heater]]></title>
<description><![CDATA[<p>hi .my water heater will not ignite automatically. if i turn on water and then turn on heater it ignites .but if i switch if i turn on water while its on it will not ignite. also if i leave it turned on with water off it tries to ingnite.the lcd stays on also .be great and much appreciated if anyone can help</p>
<p>⟐ Answer edited setembro 25, 2025 at 23:56 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/918827/tabodd+16l+gas+water+heater</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/918827</guid>
<pubDate>Thu, 25 Sep 2025 23:56:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Leaking Heat pump water heater, AO Smith HPTU-50N130]]></title>
<description><![CDATA[<div class="clearer"></div><div class="headerContainer"><h2 id="Section_Heat_pump_water_heater_AO_Smith_HPTU_50N130" class="header">Heat pump water heater, AO Smith HPTU-50N130</h2></div>
<p><strong><a href="https://www.houzz.com/user/chris-stillman" rel="nofollow noopener noreferrer" target="_blank">Chris Stillman</a></strong></p>
<p>***1 minute ago</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/SIpGN5gRAhWl3Cer.standard" width="282" height="211" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/SIpGN5gRAhWl3Cer.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="clearer"></div><div class="headerContainer"><h2 id="Section_" class="header"><div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/jbsn5MASBCvpJtDc.standard" width="169" height="225" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/jbsn5MASBCvpJtDc.huge&quot;, '', 'width=900,height=1200')" /></div></h2></div>
<p>UPDATE: The leak is coming from the bottom device. I'm looking into this manual if that pulls out, etc. Any input is welcome.</p>
<p>***</p>
<p>Hello, I woke up to a nice puddle of water underneath the water heater. It is spraying water out from the inside. The water is literally spraying out from behind the section in the photo attached.</p>
<p>I may be in over my head on this one but figured I'd check in with you guys!</p>
<p>Thank you!</p>
<p>⟐ Commented junho 07, 2025 at 19:30 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/902952/Leaking+Heat+pump+water+heater,+AO+Smith+HPTU-50N130</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/902952</guid>
<pubDate>Sat, 07 Jun 2025 19:30:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Not boiling? My geyser not boiling]]></title>
<description><![CDATA[<p>Not boiling ?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_04_25_Num_25" class="header">Update (04/25/25)</h3></div>
<p>My geyser not boiling</p>
<p>⟐ Edited abril 25, 2025 at 1:39 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/897566/Not+boiling+My+geyser+not+boiling</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/897566</guid>
<pubDate>Fri, 25 Apr 2025 01:39:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Can I heat water using only the bottom element? (Just rewire)]]></title>
<description><![CDATA[<p>I have a Bradford White water heater that is going to be replaced.  I just can't get it done very quickly.</p>
<p>The top element is shot. Power but no heat.</p>
<p>Can I rewire it so that when the upper thermostat tries to power the upper element, it goes instead to the lower thermostat?</p>
<p>Clearly the upper thermostat is going to be too cold to turn off for a long time. Until then, it would provide power to the lower thermostat which should also turn on the lower element until there's enough hot water in the bottom of the tank.</p>
<p>Relying on convection to mix the upper and lower parts of the tank, I would expect to get at least lukewarm water with the bottom thermostat cycling on and off pretty regularly.  If it ever gets to the desired temp, either the top or bottom thermostat will kill power to the lower element.</p>
<p>Based on the B-W installation manual, I would accomplish this by</p>
<p>(1) Disconnecting the upper element from the upper thermostat by removing the yellow wire from T2.</p>
<p>(2) Move the black wire on T4 (lower thermostat power) from T4 to T2.</p>
<p>See page 7 of the manual ta <a href="https://www.manualslib.com/manual/20112/Bradford-White-M-2-50t6ds.html?page=3#manual" rel="nofollow noopener noreferrer" title="https://www.manualslib.com/manual/20112/Bradford-White-M-2-50t6ds.html?page=3#manual">https://www.manualslib.com/manual/20112/...</a></p>
<p>This will cause the lower thermostat to be powered anytime the temperature on the upper thermostat would call for heat.</p>
<p>Only has to last a week or so.</p>
<p>Thanks!</p>
<p>⟐ Edited by author janeiro 12, 2025 at 18:49 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/883543/Can+I+heat+water+using+only+the+bottom+element+(Just+rewire)</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/883543</guid>
<pubDate>Sun, 12 Jan 2025 18:49:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Ferroli Optimax HE 18S boiler. Error code T5.]]></title>
<description><![CDATA[<p>Need help with Ferroli Optimax HE 18S boiler. Error code T5.</p>
<p>Have reset and got flashing P01 but nothing happens. Was working night before last. It was very cold overnight and last night wouldn't come on. Have tried to investigate this evening but all guidance says to reset and when P01 appears, system should fire up.</p>
<p>Nothing happening, house freezing, no other source of heating.</p>
<p>😢🥶</p>
<p>⟐ Answered novembro 23, 2024 at 9:23 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/877982/Ferroli+Optimax+HE+18S+boiler.+Error+code+T5.</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/877982</guid>
<pubDate>Sat, 23 Nov 2024 09:23:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: No hot water in boiler, keeps flashing F5?]]></title>
<description><![CDATA[<p>My furriol boiler keeps flashing F5, and am only getting hot water for a couple of seconds at a time, will i need to get a new boiler, or can this be fixed?</p>
<p>⟐ Commented novembro 21, 2024 at 10:51 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/73381/No+hot+water+in+boiler,+keeps+flashing+F5</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/73381</guid>
<pubDate>Thu, 21 Nov 2024 10:51:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Ferroli DOMICompact F24B F5 error]]></title>
<description><![CDATA[<p>I also have the issue of the fan not working and error code F5 as someone else posted a few years back, but in my case, the fan is ok, has continuity and resistance of 47.6 ohms and is free moving.</p>
<p>The issue is, the fan isn’t getting power from the PCB so is the PCB at fault or is there something else I can check? Can anyone help?</p>
<p>⟐ Answer accepted outubro 31, 2024 at 9:46 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/658407/Ferroli+DOMICompact+F24B+F5+error</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/658407</guid>
<pubDate>Thu, 31 Oct 2024 09:46:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Why don't I have hot water.ive replaced both elements and thermostat]]></title>
<description><![CDATA[<p>I've got power to both elements and thermostat and still no hot water</p>
<p>⟐ Commented setembro 08, 2024 at 19:16 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/868644/Why+don&#039;t+I+have+hot+water.ive+replaced+both+elements+and+thermostat</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/868644</guid>
<pubDate>Sun, 08 Sep 2024 19:16:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: fine until a few days ago. Now it only put out warm water.]]></title>
<description><![CDATA[<p>My AO Smith electric water heater has two compartments for heating elements but has a plug in the top and only has the lower element and thermostat. Iit has been working fine until a few days ago. Now it only put out warm water. I turned the thermostat up all the way and no chNge.</p>
<p>⟐ Commented agosto 17, 2024 at 1:28 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/865089/fine+until+a+few+days+ago.+Now+it+only+put+out+warm+water.</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/865089</guid>
<pubDate>Sat, 17 Aug 2024 01:28:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Viessmann Duomatik: Procedure to set up the control unit after replacing the battery]]></title>
<description><![CDATA[<p>I have a faulty Viessmann Duomatic. It appears that the battery inside the control unit is dead. I have just had a heating engineer come and, after consulting with Viessmann over the phone, got my boiler working again by pressing a few buttons on the control unit. He told me the battery was 'tired' and warned me not to turn the power off until I had replaced the control unit (£450). I can easily change the battery but what buttons do I need to press to re-initialise the control unit or will it just work once the 3.6v battery has been replaced?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_07_05_Num_24" class="header">Update (07/05/24)</h3></div>
<p>The control unit was basically not displaying any of the values for the three thermistors connected to it, it is as if it wasn't looking at the sensors and the codes that were entered by the heating engineer initialised the controller to look at the sensors and display the values on the display. Without a valid temperature for the boiler it wouldn't do jack. Is there not a Viessmann engineer out there with access to the engineering manual that could look up the initialisation procedure for me?</p>
<p>⟐ Commented julho 06, 2024 at 10:02 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/856962/Procedure+to+set+up+the+control+unit+after+replacing+the+battery</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/856962</guid>
<pubDate>Sat, 06 Jul 2024 10:02:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Vaillant wall gas water heater system]]></title>
<description><![CDATA[<p>Vaillant gas water heater system</p>
<p>⟐ Edited abril 11, 2024 at 7:09 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/844533/Vaillant+wall+gas+water+heater+system</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/844533</guid>
<pubDate>Thu, 11 Apr 2024 07:09:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Mx inspiration qi Why is my water cold?]]></title>
<description><![CDATA[<p>My electric shower is only running cold water. The electrics for it seem ok. But it all started after an electric trip in our house. Is there any way to resolve it?</p>
<p>⟐ Commented fevereiro 16, 2024 at 7:52 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/837178/Mx+inspiration+qi+Why+is+my+water+cold</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/837178</guid>
<pubDate>Fri, 16 Feb 2024 07:52:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: How often does a tankless water heater need to be descaled?]]></title>
<description><![CDATA[<p>I have a Rinnai RL94 Tankless hot water heater. It’s not clear to me from the owner’s manual whether the unit needs to be descaled regularly, or whether it’s all right to wait for one of the corresponding “LC” warning codes to appear. I know this depends on the hardness of my local water supply. Is this something that I would be doing pre-emptively, or is it all right to just wait for the warning?</p>
<p>⟐ Commented dezembro 16, 2023 at 1:01 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/689767/How+often+does+a+tankless+water+heater+need+to+be+descaled</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/689767</guid>
<pubDate>Sat, 16 Dec 2023 01:01:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Heater: Baxi Luna3 boiler runs out of hot water?]]></title>
<description><![CDATA[<p>Afternoon, I have a Baxi Luna 3 Comfort Combi Unit, The boiler goes on when I open faucets or showers, But goes cold in about 5 minutes tops, Then takes forever to heat up again. Cant even take showers. The unit is 2 years old, I checked the heat exchanger and flushed it out just incase of scaling or slime. Some dirt but nothing to stop water flow. This has been a constant issue. Was a direct replacement with an old baxi unit due to hurricane sandy.</p>
<p>⟐ Answered novembro 02, 2023 at 15:03 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/180631/Baxi+Luna3+boiler+runs+out+of+hot+water</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/180631</guid>
<pubDate>Thu, 02 Nov 2023 15:03:01 -0700</pubDate>
</item>
</channel>
</rss>
