<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Samsung ATIV Book 9 Plus&quot;]]></title>
<link>https://pt.ifixit.com/Answers/Device/Samsung_ATIV_Book_9_Plus?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Samsung ATIV Book 9 Plus&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 19 Jul 2026 08:11:20 -0700</pubDate>
<item>
<title><![CDATA[Samsung ATIV Book 9 Plus: Laptop shuts off unexpectedly]]></title>
<description><![CDATA[<p>First, my laptop is a Samsung Ativ Book 8 (NP880Z5E), not an Ativ Book 9. The book 8 wasn't an option in the model list.</p>
<p>A little background info: I've owned this laptop for about 3 years now. A few months ago, the female charging socket on the laptop started to loose connection with the male charging cable, and required a lot of baby sitting the charger to ensure it would stay charged. Yesterday I replaced the charging socket with a brand new one. Install went smoothly, and wasn't too complicated.</p>
<p>After replacing the charging socket, the PC charged up fine, and booted up without issue. Once up and running, I connected to the internet, and briefly browsed the internet and started watching some videos on youtube. After roughly 30-45 min, the PC just shut off. (Not started to shut down, just when black as if I was holding down the power button.) About 30 min later, I tried to boot back up, and was able to login and continue watching some youtube videos. Again, about 30 min later, it shut off again without warning.</p>
<p>I'm thinking this could be a cooling issue, and have placed the back of my hand on the usual warm spots on the exterior of the laptop; not noticing anything hotter than normal. Short of checking the processor temp as its running, I'm lost.</p>
<p>Anyone have any ideas, or happen to run into this in the past? Any help is greatly appreciated.</p>
<p>*****UPDATE as of 1/4/2018******</p>
<p>I have looked up my cpu's maximum operating temp and checked each cores temp while running, as well as checked/ cleaned my cooling fans. The fans are running at good speed like they should, and the internal core temps are well below maximum. So this doesn't seem to be the issue.</p>
<p>Samsung support recommended that I run a battery diagnostics test from the boot menu, however, the laptop wont stay on long enough to run it. Every time I tried to run the test, the laptop would completely shut off before I could even start the test. However, I'm not completely convinced the battery is the problem, because it charges all the way to 100% when hooked up, and seems to hold the charge like normal. (Unless there's something I'm un aware of.)</p>
<p>⟐ Answered outubro 30, 2018 at 12:35 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/451657/Laptop+shuts+off+unexpectedly</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/451657</guid>
<pubDate>Tue, 30 Oct 2018 12:35:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung ATIV Book 9 Plus: How to upgrade SSD?]]></title>
<description><![CDATA[<p>I've opened the back cover and removed the battery, but I see no mSATA.  Where is it?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_09_25_Num_2015" class="header">Update (09/25/2015)</h3></div>
<p>Please see the pictures I've posted of the inside of the Ativ book 9+.  Is there an mSATA SSD in this laptop?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_09_25_Num_2015_1" class="header">Update (09/25/2015)</h3></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/SSTfv3ZFXTg4oZCJ.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/SSTfv3ZFXTg4oZCJ.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/AYHnpPIKUhRPV1j6.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/AYHnpPIKUhRPV1j6.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>Attached pictures.</p>
<p>⟐ Answered setembro 28, 2015 at 7:56 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/257457/How+to+upgrade+SSD</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/257457</guid>
<pubDate>Mon, 28 Sep 2015 07:56:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung ATIV Book 9 Plus: The black wide ribbon cable between the sub and main board]]></title>
<description><![CDATA[<p>That cable you remove in thus tutorial between the sub and main board below the fams what is it called what is its part number and where can i buy it? thanks.</p>
<p>⟐ Commented outubro 13, 2018 at 0:46 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/319942/The+black+wide+ribbon+cable+between+the+sub+and+main+board</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/319942</guid>
<pubDate>Sat, 13 Oct 2018 00:46:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung ATIV Book 9 Plus: My keys are sticky, how do I fix this?]]></title>
<description><![CDATA[<p>I spilled red wine all over my laptop keyboard, and my computer survived! But my keys are sticky and slow to respond, and I don't know how to fix this. What should I do?</p>
<p>⟐ Answered outubro 07, 2019 at 7:02 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/223023/My+keys+are+sticky,+how+do+I+fix+this</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/223023</guid>
<pubDate>Mon, 07 Oct 2019 07:02:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung ATIV Book 9 Plus: Why won't my computer turn on?]]></title>
<description><![CDATA[<p>My computer has been having issues with suddenly shutting down without warning, and my battery indicator in my Windows Taskbar has been stating for the past month that my battery is damaged. Today, when trying to turn on my computer, I found that it was completely unresponsive. Despite plugging my laptop into a power source, pressing the power button does not do anything. What do I do?</p>
<p>⟐ Answered abril 03, 2019 at 14:53 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/223022/Why+won&#039;t+my+computer+turn+on</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/223022</guid>
<pubDate>Wed, 03 Apr 2019 14:53:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung ATIV Book 9 Plus: Can anyone tell me how to release this type of cable connector]]></title>
<description><![CDATA[<p>I'm replacing the battery on my Samsung Ativ Book 9 Lite (I've posted this under Plus because Lite didn't appear as an action).</p>
<p>I need to disconnect the cable connector - would be very grateful if someone could let me know how to do it. There's a photo of the connector here:</p>
<p><a href="https://goo.gl/photos/uC8e8kAG7CdqV3vj8" rel="nofollow noopener noreferrer">https://goo.gl/photos/uC8e8kAG7CdqV3vj8</a></p>
<p>It's very small - just over 1cm wide - and there doesn't appear to be a flap to lift as there is with frictionless connectors.</p>
<p>Look forward to hearing from anyone who can help with this. I've searched Youtube videos and websites but can't find any with advice on t his type of connector. I obviously don't want to force it and break it.</p>
<p>⟐ Answer accepted novembro 01, 2016 at 8:45 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/349230/Can+anyone+tell+me+how+to+release+this+type+of+cable+connector</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/349230</guid>
<pubDate>Tue, 01 Nov 2016 08:45:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung ATIV Book 9 Plus: Which tape/glue for screen replacement to rejoin screen and backcover]]></title>
<description><![CDATA[<p>Hi everyone,</p>
<p>I'm trying to rejoin my screen and my back cover , but I don't know which tap I should use.</p>
<p>Currently, i'm using 3m tape, but it's not good at all.</p>
<p>Could any one give me a suggestion? Thanks so much</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/496329/Which+tape-glue+for+screen+replacement+to+rejoin+screen+and+backcover</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/496329</guid>
<pubDate>Wed, 27 Jun 2018 10:11:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung ATIV Book 9 Plus: The Akku charge electronic fails]]></title>
<description><![CDATA[<p>Samsung support would charge me a complete mainboard replacement but the tech told me only the part for charging the akku on the mainboard seems to be malfunctioning. Till now i didn't find anybody willing the fix such a small mainboard part. is there hope?</p>
<p>symptoms:</p>
<p>Bluescreens</p>
<p>display flimmer</p>
<p>shutdowns</p>
<p>will sometimes boot to windows but if plugged out and plugged in again, the system crashes</p>
<p>after a few tries the keyboard backlight on one side also disappeared</p>
<p>⟐ Edited by author julho 18, 2016 at 4:48 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/323338/The+Akku+charge+electronic+fails</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/323338</guid>
<pubDate>Mon, 18 Jul 2016 04:48:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung ATIV Book 9 Plus: Can I replace only the digitizer of Ativ Book 9 Plus?]]></title>
<description><![CDATA[<p>My Ativ Book 9 Plus screen has cracked and now the touch screen went crazy.</p>
<p>I know how to replace the full screen, but wanted to check if it is possible to replace only the cracked digitizer.</p>
<p>Thanks in advance.</p>
<p>Alex</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/292958/Can+I+replace+only+the+digitizer+of+Ativ+Book+9+Plus</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/292958</guid>
<pubDate>Thu, 25 Feb 2016 23:00:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung ATIV Book 9 Plus: New PC can't login on Win 8?]]></title>
<description><![CDATA[<p>I just got this netbook and can't get past the initial login. It doesn't recognize either my MicroSoft username/password or my personal username/password. Tried Admin with no password and that didn't work. Don't know where to go from here?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/248528/New+PC+can&#039;t+login+on+Win+8</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/248528</guid>
<pubDate>Thu, 13 Aug 2015 07:35:59 -0700</pubDate>
</item>
</channel>
</rss>
