<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Ninja Air Fryer&quot;]]></title>
<link>https://pt.ifixit.com/Answers/Device/Ninja_Air_Fryer?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Ninja Air Fryer&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 09 Aug 2026 22:19:12 -0700</pubDate>
<item>
<title><![CDATA[Ninja AF161 Max XL: Como recuperar cesto de Teflon com desgaste da pintura]]></title>
<description><![CDATA[<p>O cesto de minha Air freyer após algumas limpezas enferrujou e ao tentar limpar, ele desgastou o tefon, como recuperar esse desgaste no Teflon?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/919331/Como+recuperar+cesto+de+Teflon+com+desgaste+da+pintura</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/919331</guid>
<pubDate>Sat, 27 Sep 2025 12:38:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Foodi SP101: How to Remove Side Panel?]]></title>
<description><![CDATA[<p>I have been struggling to get the side panel on this removed. I am aware the guide here says to unscrew the 3 screws and then push the panel towards the control panel until the clips are visibly detached</p>
<p>However I have not been able to produce this result with varying levels of force. There is something towards the control panel that is firmly holding that side of the panel in place no matter what I try.</p>
<p>⟐ Answered junho 02, 2026 at 12:04 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/902029/How+to+Remove+Side+Panel</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/902029</guid>
<pubDate>Tue, 02 Jun 2026 12:04:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Air Fryer: Plugged 110v air fryer into 220v plug! Can it be fixed?]]></title>
<description><![CDATA[<p>I accidentally plugged my Ninja air fryer, purchased from the United States, 110v plug, into an extension board that was plugged into a 220v wall socket, and it immediately gave a loud “pop&quot; and there was a very faint smell of smoke or something, and it hasn't worked since. Can it be fixed? Or is the appliance damaged beyond repair?</p>
<p>⟐ Answer edited agosto 19, 2024 at 8:17 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/675229/Plugged+110v+air+fryer+into+220v+plug!+Can+it+be+fixed</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/675229</guid>
<pubDate>Mon, 19 Aug 2024 08:17:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Foodi DZ401: Does anyone have a wiring schematic for the Ninja Foodi DZ401?]]></title>
<description><![CDATA[<p>Does anyone have a wiring diagram or schematic for the Ninja DZ401? I would even be satisfied with a block diagram of major components.</p>
<p>Thanks in advance</p>
<p>⟐ Commented março 07, 2025 at 7:56 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/890346/Does+anyone+have+a+wiring+schematic+for+the+Ninja+Foodi+DZ401</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/890346</guid>
<pubDate>Fri, 07 Mar 2025 07:56:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Foodi SP101: Is it possible to disable the speaker?]]></title>
<description><![CDATA[<p>The oven makes a sharp, annoying beeping sound when finished that wakes up our baby. Is it possible to remove the speaker or even just put tape over it to reduce the sound?</p>
<p>⟐ Answered maio 23, 2024 at 2:24 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/850539/Is+it+possible+to+disable+the+speaker</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/850539</guid>
<pubDate>Thu, 23 May 2024 02:24:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Air Fryer: Does not stop cooking when you pull out to shake.]]></title>
<description><![CDATA[<p>Does not pause automatically when you pull out the drawer. It keeps cooking.</p>
<p>⟐ Answered fevereiro 21, 2023 at 6:14 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/665768/Does+not+stop+cooking+when+you+pull+out+to+shake.</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/665768</guid>
<pubDate>Tue, 21 Feb 2023 06:14:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Foodi SP101: Need the fans model numbers]]></title>
<description><![CDATA[<p>What are the model number of the fans in this unit? Are they available online?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/942829/Need+the+fans+model+numbers</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/942829</guid>
<pubDate>Sun, 01 Mar 2026 11:43:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja AF100: The fan is not working]]></title>
<description><![CDATA[<p>First, it was making a loud noise.  Next, the fan stopped working.  How do I replace the fan?  Part number?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/933753/The+fan+is+not+working</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/933753</guid>
<pubDate>Sat, 03 Jan 2026 14:56:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Air Fryer: I need help identifying two resistors on the main board for air fryer]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I am trying to repair my Ninja Speedi ON400UK. I found two resistors melted along with the IC at the back of the main PCB board. (I have managed to identify the IC, which is PN603H, but the resistors are completely unreadable - they are marked as R26 &amp; R227 on the picture).</p>
<p>Does anyone have the same model or has repaired one in the past and can help me with the values of these two SMD resistors, please (share a photo ideally)?</p>
<p>The main PCB board is located behind the cover with the clips, so I needed to remove two screws at the bottom, squeeze it on both sides and pull it to remove the plastic cover and get to the PCB board.</p>
<p>I will be grateful for any kind of help.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/eBMVAmmQRspFLyvS.standard" width="282" height="211" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/eBMVAmmQRspFLyvS.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/qAF2lSSIJDjLUM5J.standard" width="169" height="225" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/qAF2lSSIJDjLUM5J.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Edited outubro 16, 2025 at 8:08 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/922105/I+need+help+identifying+two+resistors+on+the+main+board+for+air+fryer</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/922105</guid>
<pubDate>Thu, 16 Oct 2025 08:08:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Foodi DZ401: I need to purchase the outer casing]]></title>
<description><![CDATA[<p>I would like to know where I can buy the outer casing of this machine to be replaced. I really appreciate your help.</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/903544/I+need+to+purchase+the+outer+casing</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/903544</guid>
<pubDate>Thu, 12 Jun 2025 20:33:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Foodi SP101: What is control board part #? Where I can buy?]]></title>
<description><![CDATA[<p>What is control board part # ? Where I can buy ?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/878054/What+is+control+board+part+%23+Where+I+can+buy</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/878054</guid>
<pubDate>Sat, 23 Nov 2024 10:27:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Foodi FD401: Doesn't shut off when you open lid]]></title>
<description><![CDATA[<p>Why doesn't my grill turn off when I lift lid?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/840102/Doesn&#039;t+shut+off+when+you+open+lid</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/840102</guid>
<pubDate>Fri, 08 Mar 2024 10:21:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ninja Air Fryer: after clean the inside top, the heat become very low]]></title>
<description><![CDATA[<p>after clean the top, heat become very low, why?</p>
<p>⟐ Answer edited fevereiro 02, 2023 at 11:50 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/750365/after+clean+the+inside+top,+the+heat+become+very+low</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/750365</guid>
<pubDate>Thu, 02 Feb 2023 11:50:03 -0700</pubDate>
</item>
</channel>
</rss>
