<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;MacBook Pro 17&quot;&quot;]]></title>
<link>https://pt.ifixit.com/Answers/Device/MacBook_Pro_17%22/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;MacBook Pro 17&quot;&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 08 Aug 2026 02:49:54 -0700</pubDate>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: MacBook Pro não esta ligando..]]></title>
<description><![CDATA[<p>Ola pessoal, fiz todos os procedimentos, troquei memoria, já tirei a bateria e coloquei...</p>
<p>Depois de uma viajem que fiz ele ficou com esse problema, imaginei algo por ter sido do ar condicionado.</p>
<p>Depois eu fiz alguns teste e nada, porem peguei o secador de cabelo e apontei para placa mãe, deu certo ele ligou, só que quando desligo e espero um tempinho não liga!!</p>
<p>Ele volta quando esquento a placa...</p>
<p>⟐ Answered junho 10, 2018 at 4:35 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/482719/MacBook+Pro+n%C3%A3o+esta+ligando..</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/482719</guid>
<pubDate>Sun, 10 Jun 2018 04:35:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: 2010 17" MacBook Pro: certain keys keep repeating]]></title>
<description><![CDATA[<p>Hi, I have a 2010 17” MacBook Pro (not the dreaded 2011 MacBook Pro…).</p>
<p>Recently, keys in the top-right hand section of the keyboard have started repeating continuously. The worst are the volume up/down function keys, but also others such as the “\” key.</p>
<p>I thought that the keyboard was probably the problem so I transplanted the logic board into a spare identical 17” MacBook Pro case that included its own keyboard, and the problem moved with the logic board. Hence I presume the problem lies with the logic board.</p>
<p>The Mac has been extremely reliable until a couple of years ago when I had the board repaired for a different problem but now I’m reluctant to spend more money on it.</p>
<p>Any ideas as to what could be causing the problem, and how to rectify it? Or is it time to retire the MacBook Pro? Thank you.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_11_01_Num_2020" class="header">Update (11/01/2020)</h3></div>
<p>Thanks Dan. Please see the two images attached - one of the connector with the keyboard ribbon cable connected, and one of the end of the unconnected ribbon cable. But, as described in my original post, this is the second case and keyboard (and hence the second keyboard cable) that I’ve tried and it seems unlikely to me that the same problem would persist between two separate keyboards and keyboard cables, etc. Thanks for your help.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/U6pTAvQYsqpA3NxF.standard" width="282" height="211" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/U6pTAvQYsqpA3NxF.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/jGXywGIsGJHkoTeS.standard" width="282" height="211" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/jGXywGIsGJHkoTeS.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>⟐ Answered maio 26, 2026 at 11:32 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/664122/2010+17%22+MacBook+Pro:+certain+keys+keep+repeating</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/664122</guid>
<pubDate>Tue, 26 May 2026 11:32:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: Thunderbolt Port not working correctly!]]></title>
<description><![CDATA[<p>Here's whats going on, I have a Zoom TAC-2 Thunderbolt Audio interface which I've been using for sometime with another macbook pro 17&quot; and it had no problems on a macbook air either..</p>
<p>Just today I tried the interface on two different 17-inch macbook pros of mine (one running High Sierra the other is El Capitan and it appears to get no power from either of them. At this stage I was thinking okay this has to be either the thunderbolt cable or the Interface has died on me somehow. First I hooked one computer to the other in target disk mode to test the cable, no trouble getting target disk to do it's thing,  but I went ahead and bought a  genuine apple cable anyway just to be sure, still no signs of life from the interface.</p>
<p>Finally in a &quot;there is no way this is going to work but what the heck&quot; moment I tried hooking it up to my brothers same 2011 model macbook pro 17 and voilà, it does its usual LED streak up light. This made me happy but it still leaves a lot of questions about my 2 macbook pros and their thunderbolt ports.</p>
<p>Is it possible they're not providing power through the correct pins? The pins look clean to me so I don't see any obvious issue and the fact it works for target disk mode also seems strange. Anyone have any ideas of what to try or similar experiences not getting power from their thunderbolt ports? Could this be software even?</p>
<p>Thanks!</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/1H5MSTyX63PeFoHw.standard" width="282" height="155" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/1H5MSTyX63PeFoHw.full&quot;, '', 'width=389,height=213')" /></div>
<p>⟐ Commented fevereiro 09, 2026 at 19:56 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/481122/Thunderbolt+Port+not+working+correctly!</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/481122</guid>
<pubDate>Mon, 09 Feb 2026 19:56:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Models A1151 A1212 A1229 and A1261: Coffee on Keyboard. keys and trackpad clicking no longer work...]]></title>
<description><![CDATA[<p>What parts will I need to replace? The keys no longer work or light up, and the trackpad works other than not being able to one or two finger click with it. The trackpad button still works to click</p>
<p>⟐ Commented novembro 20, 2025 at 11:32 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/14711/Coffee+on+Keyboard.+keys+and+trackpad+clicking+no+longer+work...</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/14711</guid>
<pubDate>Thu, 20 Nov 2025 11:32:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: Anyone have the 13-pin battery pinout for this battery model A1309]]></title>
<description><![CDATA[<p>Looking for the battery or power connector pinout for this model its a early 2011 17&quot; MBP A1297 EMC 2352. The battery model is A1309. The board number is 820-2849-A if someone has the power section of the schematic handy that should work too.</p>
<p>MBRT has the pinout looped in with the 9-pin batteries and that clearly cannot be correct. The slim 13-pin battery connector battery model is A1309</p>
<p>⟐ Answered setembro 06, 2025 at 20:15 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/915868/Anyone+have+the+13-pin+battery+pinout+for+this+battery+model+A1309</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/915868</guid>
<pubDate>Sat, 06 Sep 2025 20:15:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Models A1151 A1212 A1229 and A1261: Blown chip in position D7700, unknown value]]></title>
<description><![CDATA[<p>I was working on my MacBook Pro, when I decided to reconnect the right fan, since it had been unplugged for making a rattling noise. I lubricated it, and yet it still felt just a bit stiff. When I turned on the computer with it plugged in, it took a push to get it spinning, but it seemed to work. Then, smoke comes out from under the logic board. The component I find to be blown is in position D7700, but I do not know what kind of component it is (I assumed that it was a diode, since the position started with <em>D</em>), or what value. It is a small rectangular chip, with two legs on the left and right on the bottom, and one leg on the top that is centered. Amazingly, the rest of the system still seemed to be working, including the USB port and the optical drive. Also, the system booted and I was able to install El Capitan. So, what component could this be, and at what value?</p>
<p>⟐ Commented junho 29, 2025 at 7:42 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/902959/Blown+chip+in+position+D7700,+unknown+value</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/902959</guid>
<pubDate>Sun, 29 Jun 2025 07:42:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: Can I interchange parts 2 MacBook models]]></title>
<description><![CDATA[<p>From a MacBook 17” unibody-A1297 and an  13” mbp- A1495. One doesn’t turn on and the other gets a file with a question mark. I was hoping I could Frankenstein them and make one that works.</p>
<p>⟐ Answered junho 23, 2025 at 5:30 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/904752/Can+I+interchange+parts+2+MacBook+models</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/904752</guid>
<pubDate>Mon, 23 Jun 2025 05:30:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: Best repair place to replace the AMD GPU]]></title>
<description><![CDATA[<p>I can get the logic board board out of my 17&quot; unibody MacBook Pro, but I don't have a way to test the AMD GPU. My best guess is that the solder BGA is defective.</p>
<p>Suggestions about a good repair place to send the board to. I know that if the GPU is also defective, I can, at best, expect a used AMD GPU. That's OK. I also know that the cost is going to be high.</p>
<p>What I need to know is who has had good results, and with what repair places.</p>
<p>I may also buy a &quot;warranted&quot; replacement logic board to have on hand.</p>
<p>Thanks for any replies.</p>
<p>⟐ Commented maio 25, 2025 at 4:33 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/901144/Best+repair+place+to+replace+the+AMD+GPU</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/901144</guid>
<pubDate>Sun, 25 May 2025 04:33:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17": Display, flickering green lines]]></title>
<description><![CDATA[<p>I have a mid 2009 17in MBP 2.8GHz.</p>
<p>The screen/display flickers with green symmetrical lines at random times. Its makes watching a video or gaming frustrating. They so up almost symmetrical around images.</p>
<p>I did find a temporary fix doing a google search.</p>
<p>If I apply pressure with my hand to the bottom of the laptop underneath the area of the left option key, it magically goes away. When I release the pressure it comes back.</p>
<p>Is there a permanent fix?</p>
<p>⟐ Answered maio 13, 2025 at 12:12 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/166011/Display,+flickering+green+lines</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/166011</guid>
<pubDate>Tue, 13 May 2025 12:12:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17": Kerenal task using 80% cpu]]></title>
<description><![CDATA[<p>Hi there i have a macbook 2017 it was working fine but after some day all the fans are on for no reason even the laptop is cold and the fans keep spinning till i shut down my laptop i open Activity monitor it says kernel task using 80% cpu can you please help me with this</p>
<p>⟐ Commented abril 01, 2025 at 18:24 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/894328/Kerenal+task+using+80%25+cpu</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/894328</guid>
<pubDate>Tue, 01 Apr 2025 18:24:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Models A1151 A1212 A1229 and A1261: A1261 MBP won't turn on after screen repair]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I've just followed the iFixit guide to remove the LCD panel from my 2008 MBP (<a href="/Guide/Substitui%C3%A7%C3%A3o+do+LCD+do+MacBook+Pro+17-Inch+modelos+A1151+A1212+A1229+e+A1261/2724">Substituição do LCD do MacBook Pro 17&quot; modelos A1151, A1212, A1229 e A1261</a>) to complete a repair (actually to re-stick the white card behind the Apple logo which had slipped and left an ugly black line across it)!</p>
<p>Unfortunately, having put everything back together, the MBP won't power on at all. I press the power button and there is no chime, no sound from the Superdrive, nothing. Not a display issue, just an entire laptop power issue. :( When I connect the MagSafe cable (with or without the battery connected) the charging light goes green. I've tried with the battery in and out. I've tried holding the power button down with no battery/cable connected for 10 seconds then booting again. Still nothing. And it was working absolutely fine before I stupidly decided to try and repair it - Could boot up on or off the charging cable, even on battery power. :'(</p>
<p>Any thoughts? Does the power button run through the right-side cable from the screen display (as in this picture <a href="https://guide-images.cdn.ifixit.com/igi/NWjHlDGSULFukQCS.huge" title="https://guide-images.cdn.ifixit.com/igi/NWjHlDGSULFukQCS.huge">https://guide-images.cdn.ifixit.com/igi/...</a>)? Is it possible I damaged that cable when removing/re-seating the display?</p>
<p>And I know its an old laptop, but it was an eBay find in good condition and I was hoping to play around with it a bit longer than this!</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_01_25_Num_25" class="header">Update (01/25/25)</h3></div>
<p>Sorry, ignore me. ☺️ Seems like the battery was just completely dead. Screwed everything back together, left it on the charger for a few minutes and like magic it powered up again. 😀</p>
<p>⟐ Answer accepted janeiro 26, 2025 at 7:45 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/885422/A1261+MBP+won&#039;t+turn+on+after+screen+repair</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/885422</guid>
<pubDate>Sun, 26 Jan 2025 07:45:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: WiFi Connector Replacement in a MacBook Pro 17" 2009 Laptop Question]]></title>
<p>I'm trying to replace the WiFi connector on my MacBook Pro 2009 motherboard, because I bent the pins on it accidentally during a routine check on the motherboard</p>
<p>I removed the connector, but now I've got ripped-pads that I'm trying to fix.</p>
<p>The situation is similar to the following (note not all of the pads shown are ripped, but some are):</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/4kah16cDQCbpWc5o.standard" width="282" height="158" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/4kah16cDQCbpWc5o.full&quot;, '', 'width=1920,height=1080')" /></div>
<p>I think that I understand all of the situations except for one:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/NePI4PeCNPXKNiA6.standard" width="282" height="165" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/NePI4PeCNPXKNiA6.full&quot;, '', 'width=1393,height=814')" /></div>
<p>The two pads circled are indeed ripped, so I'm going to need to fix them.</p>
<p>Does anyone know what this trace is doing? Is it a single connector going back to the same pin? It seems silly because why would the manufacturers bother if the pin goes nowhere?</p>
<p>James Pedersen</p>
<p>⟐ Answer edited outubro 31, 2024 at 19:21 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/875581/WiFi+Connector+Replacement+in+a+MacBook+Pro+17%22+2009+Laptop+Question</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/875581</guid>
<pubDate>Thu, 31 Oct 2024 19:21:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Models A1151 A1212 A1229 and A1261: Would it, in theory, be possible to complete upgrade the logic board?]]></title>
<description><![CDATA[<p>I think that the external design of this series of MacBook Pro was just wonderful, the black keyboards and bezels on the models which came after it just don't look as good.</p>
<p>I know that the CPU and GPU are soldered onto the logic board, so therefore, my question would be; is there any much more modern logic board that would in theory fit inside the chassis of a 17 inch A1229? I know that the connectors would be completely different, but would there be anything stopping you if you did find a logic board that fits in and you could swap out the connectors etc.</p>
<p>Clearly this doesn't make sense if you were just trying to get value out of an old machine thinking it would be cheaper, but is it even possible in theory for someone who had an abundance of time and money?</p>
<p>⟐ Answered outubro 22, 2024 at 2:04 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/850461/Would+it,+in+theory,+be+possible+to+complete+upgrade+the+logic+board</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/850461</guid>
<pubDate>Tue, 22 Oct 2024 02:04:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: MacBook Pro 17” 2009 wont turn on]]></title>
<description><![CDATA[<p>Hello, i have a 2009 macbook pro that won’t turn on, even if the green light on the charger is on.</p>
<p>I thought that the problem was the 7771 capacitor (a very common issue ), so i replaced it with a new one but it doesn’t want to turn on.</p>
<p>I measured the voltage across the capacitor and i get 1.1V which seems good (?).</p>
<p>I even tried ti turn it on by shorting the power pins but as you may imagine nothing to do… (maybe i’m doing it wrong)</p>
<p>Can someone help me?</p>
<p>⟐ Commented outubro 18, 2024 at 3:48 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/873333/MacBook+Pro+17%E2%80%9D+2009+wont+turn+on</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/873333</guid>
<pubDate>Fri, 18 Oct 2024 03:48:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: Remove and install the AMD GPU chip]]></title>
<description><![CDATA[<p>What sort of workstation would it take to remove and install the AMD Radeon HD 6750M GPU chip, and what do I want to look for on the used market to get one? Second question, are there better fans to put in a 17&quot; Unibody MacBook Pro?</p>
<p>⟐ Answer edited setembro 20, 2024 at 15:10 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/869916/Remove+and+install+the+AMD+GPU+chip</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/869916</guid>
<pubDate>Fri, 20 Sep 2024 15:10:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: One of my ram bay one accepts 2 gb stick]]></title>
<description><![CDATA[<p>Hey all, trying to revive my old 2010 uni body 17inch here.</p>
<p>Before I've always rocked a 6gb ram (4+2) and after trying to replace the 2 gig stick with a 4 gig, the macbook gives me the ram beep and will not post.</p>
<p>As I've accumulated a shocking number of ddr3 ram sticks, I've tried them all, and the onky ram bay 1 of my macbook accepts is the 2 gig sticks (I have 2 identical ones and they hoth work)</p>
<p>But when I try to introduce the socket to a 4 gig stick, it suddenly refuses the ram, even if all I'm doing is swapping the previously working 2 gig and 4 gig ram sticks around, one bay happily access any size ram, but the other only accepts the 2 gig.</p>
<p>The macbook even boots with only the 4 gig stick but not if it's in the problematic bay.</p>
<p>The rams I'm testing with are the correct voltage and speed, I'm a bit confused as why it's happening here.</p>
<p>Any ideas would help.</p>
<p>⟐ Commented setembro 18, 2024 at 14:11 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/869463/One+of+my+ram+bay+one+accepts+2+gb+stick</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/869463</guid>
<pubDate>Wed, 18 Sep 2024 14:11:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Unibody: What adhesive is safe to use for keyboard rubber cap under spacebar?]]></title>
<description><![CDATA[<p>The rubber cap or nipple, as some call it, in the center under the spacebar on my MacBook Pro 17&quot; is torn. I have ordered replacement parts. Some instructions on the web say to use super glue, some say to use silicone adhesive. What adhesive is safe for the cap or is adhesive not needed?  If not needed, how do I make sure the cap is in place when putting the spacebar back on? thank you.</p>
<p>Also, how do I remove the old one? I've tried to gently squeeze and pull but it appears to be firmly attached somehow.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/5UHugU5BMkLEWVhd.standard" width="282" height="211" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/5UHugU5BMkLEWVhd.full&quot;, '', 'width=1000,height=750')" /></div>
<p>⟐ Answered setembro 06, 2024 at 6:24 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/165280/What+adhesive+is+safe+to+use+for+keyboard+rubber+cap+under+spacebar</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/165280</guid>
<pubDate>Fri, 06 Sep 2024 06:24:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Models A1151 A1212 A1229 and A1261: MBP 17” A1212 Not turning on (but charges battery)]]></title>
<description><![CDATA[<p>I’ve tried shorting the PWR BTN pins but it doesn’t do anything, no fans, no superdrive spinning up no hard drive spinning up, nothing just absolutely nothing</p>
<p>im using a 85w MagSafe charger btw</p>
<p>⟐ Commented agosto 12, 2024 at 14:39 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/861262/MBP+17%E2%80%9D+A1212+Not+turning+on+(but+charges+battery)</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/861262</guid>
<pubDate>Mon, 12 Aug 2024 14:39:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Models A1151 A1212 A1229 and A1261: After powersurge no light on magsafe+no charge. Board or PwrSupply?]]></title>
<description><![CDATA[<p>Power went out today and the house got got a surge when power was restored. Bedroom light was much brighter than usual for 30 seconds or so. Misc. cheap Household powerstrip got fried+microwave oven no longer works. My MBP17 was running at the time and I didn't think to quickly power down when the power went out. I didn't realize till later that the magsafe was not 'green'. I always run off the powersupply. The MBP and 3 external drives are plugged into an inexpensive 'protected' powerstrip. Had no trouble with any of the hd's. I bought the powersupply a couple months ago, 'reconditioned' frrom OWC. Could it be a bad PS and just bad timing, or maybe a bad magsafe board? I don't have access to another PS. How do you check voltage with those little pins in the T-connector? Different voltage per pin? Or same v accross them all? Thanks for any help!</p>
<p>-Mike</p>
<p>MacBook Pro17&quot; a1229  <strong>Last 5 SN# digits- ...R9YAN</strong></p>
<p>More info...I tried other sockets on the ps, different outlets in my room and others around the house. I get no light from the magsafe LED at all. The MB ran just fine until the battery ran out. I was playing with garageband until I noticed the low battery, and then realized the magsafe's green light was out. No orange or red either.The battery doesn't last long at all, so I keep it plugged in 99% of the time. I'm hoping the ps is the problem and the logic and left I/O boards are undamaged. I guess I need to find someone with a MBP I can test the ps on...</p>
<p>⟐ Commented julho 28, 2024 at 21:43 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/69728/After+powersurge+no+light+on+magsafe+no+charge.+Board+or+PwrSupply</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/69728</guid>
<pubDate>Sun, 28 Jul 2024 21:43:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 17" Models A1151 A1212 A1229 and A1261: I can't install any software. Have replaced HD, but still same issue.]]></title>
<description><![CDATA[<p>I have been to Apple Store and all hardware checks ok, but I can't install any software. Have tried both installation from internet and from hard drive, but always stops before installation complete. I even tried a Linux version and similar issue - it would run off the disc, but would not install. I have replaced the hard drive, but still same issue. Any ideas if this is a hardware issue?</p>
<p>⟐ Commented julho 07, 2024 at 15:09 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/814474/I+can&#039;t+install+any+software.+Have+replaced+HD,+but+still+same+issue.</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/814474</guid>
<pubDate>Sun, 07 Jul 2024 15:09:18 -0700</pubDate>
</item>
</channel>
</rss>
