<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;LG V30 PLUS&quot;]]></title>
<link>https://pt.ifixit.com/Answers/Device/LG_V30_PLUS?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;LG V30 PLUS&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 15 Jul 2026 13:46:22 -0700</pubDate>
<item>
<title><![CDATA[LG V30 PLUS: Please help. How do I fix this on my phone?]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/yl1QZNPcoraMi4lI.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/yl1QZNPcoraMi4lI.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>I accidentally dropped my phone and when I picked it up, it showed this on my screen. It still works. I really need a solution to this or my parents are going to kill me. Please help. There is a green line on the right side and it is glitching on the entire screen.</p>
<p>⟐ Answer accepted setembro 18, 2021 at 7:16 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/706023/Please+help.+How+do+I+fix+this+on+my+phone</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/706023</guid>
<pubDate>Sat, 18 Sep 2021 07:16:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[LG V30 PLUS: Incoming Call Screen Duplicate]]></title>
<description><![CDATA[<p>My incoming call screen shows then a second later another one pops that I can't access. Cleared permission on all apps and that helped for a few hours but it came back.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/jOKTDX1CfErc5r4p.standard" width="113" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/jOKTDX1CfErc5r4p.huge&quot;, '', 'width=600,height=1200')" /></div>
<p>⟐ Commented setembro 06, 2020 at 13:35 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/653711/Incoming+Call+Screen+Duplicate</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/653711</guid>
<pubDate>Sun, 06 Sep 2020 13:35:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[LG V30 PLUS: From where can I buy LG V30 Plus Display?]]></title>
<description><![CDATA[<p>Hello<br /></p>
<p>I have LG mobile V 30+ and I want to replace the display,  Any one knows from where I can buy original LG display and how much is the cost<br /></p>
<p>Thanks</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/648827/From+where+can+I+buy+LG+V30+Plus+Display</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/648827</guid>
<pubDate>Fri, 31 Jul 2020 08:50:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[LG V30 PLUS: Recording noise issues even after replacing unit]]></title>
<description><![CDATA[<p>Hi  there - I first started noticing recording issues when sending audios  via WhatsApp - high-pitched noises like microphone feedback. At first,  it didn't always happen but then it became more frequent to the point it  is now useless.</p>
<p>I replaced the charging unit which also has the microphone and the problem persists.</p>
<p>Some other notes:</p>
<p>-  When using the LG HD Recorder, if I connect my earphones and use  Concert mode, the earphones are used for monitoring and the noise is  present even when not recording.<br /></p>
<p>- When recording videos in different modes, seems a bit random when it happens.<br /></p>
<p>- Phone calls are working normally.<br /></p>
<p>- I already did a reset to factory</p>
<p>Is there any other hardware that can be at fault? I noticed Witrigs has another mic listed (<a href="https://www.witrigs.com/oem-microphone-for-lg-v30" rel="nofollow noopener noreferrer" title="https://www.witrigs.com/oem-microphone-for-lg-v30">https://www.witrigs.com/oem-microphone-f...</a>)  and I believe this phones uses other ways of recording on certain  modes. The fact that calls are working properly makes me thing there's  something else to be replaced.</p>
<p>On  another note, as I was going to open my phone, decided to try my luck  with a battery replacement - everything worked well with that however  now there's a white-greenish line and a pink one across the screen, from  top to bottom. Already checked the screen flex cable and it doesn't  look like it was damaged. Anything else I can do or now the display unit  is also damaged?</p>
<p>Maybe it's time to retire this phone  :/</p>
<p>Thank you in advance for any help.</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/639837/Recording+noise+issues+even+after+replacing+unit</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/639837</guid>
<pubDate>Tue, 09 Jun 2020 08:24:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[LG V30 PLUS: I have a H930DS can I swap motherboards with other versions?]]></title>
<description><![CDATA[<p>I recently dropped my phone while riding my bike. I own a LG-H93DS with a cracked screen and back. The phone works well, it's just cracked. Is the motherboard compatible with other versions of the LG v30s? I.E. I take my motherboard out from my broken phone and place it in a used phone with a bad ESN and a good body. Will there be any problems?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/582599/I+have+a+H930DS+can+I+swap+motherboards+with+other+versions</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/582599</guid>
<pubDate>Sun, 04 Aug 2019 20:52:10 -0700</pubDate>
</item>
</channel>
</rss>
