<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Honda fit&quot;]]></title>
<link>https://pt.ifixit.com/Answers/Device/Honda_fit?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Honda fit&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 19 Aug 2026 14:21:06 -0700</pubDate>
<item>
<title><![CDATA[Honda fit: Como reparar trava elétrica Honda Fit 2014]]></title>
<description><![CDATA[<p>Como faço para reparar ou identificar problemas na trava elétrica do Honda Fit 2014? A trava para fechamento da porta automático fica acionando mesmo a porta já estando travada.</p>
<p>⟐ Commented julho 21, 2026 at 3:24 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/854302/Como+reparar+trava+el%C3%A9trica+Honda+Fit+2014</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/854302</guid>
<pubDate>Tue, 21 Jul 2026 03:24:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Como abrir porta, fazer reparo e nutenção básica portas Honda fit 2005]]></title>
<description><![CDATA[<p>Gostaria saber, abrir porta para aqueles querem mexer mais tem medo quebrar algo que poderia ter sido evitado com conhecimento.</p>
<p>⟐ Answered novembro 11, 2023 at 8:52 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/792614/Como+abrir+porta,+fazer+reparo+e+nuten%C3%A7%C3%A3o+b%C3%A1sica+portas+Honda+fit+2005</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/792614</guid>
<pubDate>Sat, 11 Nov 2023 08:52:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Troca do Reservatorio agua parabrisa]]></title>
<description><![CDATA[<p>Com trocar reservatorio de agua do parabrisa honda fit 2004?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/957054/Troca+do+Reservatorio+agua+parabrisa</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/957054</guid>
<pubDate>Wed, 27 May 2026 08:41:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Porque a velocidade do painel não marca km/h]]></title>
<description><![CDATA[<p>O painel liga normalmente funciona rpm e combustível mas não mostra a velocidade</p>
<p>⟐ Commented agosto 26, 2025 at 18:30 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/913987/Porque+a+velocidade+do+painel+n%C3%A3o+marca+km-h</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/913987</guid>
<pubDate>Tue, 26 Aug 2025 18:30:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: motor perde potencia quando o ar condicionado esta ligado]]></title>
<description><![CDATA[<p>o  motor  perde  potencia  na  subida  quando  o  ar condicionado  esta  ligado</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/892156/motor+perde+potencia+quando+o+ar+condicionado+esta+ligado</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/892156</guid>
<pubDate>Wed, 19 Mar 2025 10:31:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Painel fazendo barulho como estivesse solto]]></title>
<description><![CDATA[<p>Como faço para resolver esse problema de ruído?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/891681/Painel+fazendo+barulho+como+estivesse+solto</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/891681</guid>
<pubDate>Sun, 16 Mar 2025 18:20:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Como trocar a multimídia?]]></title>
<description><![CDATA[<p>Como faço para trocar a multimídia do Fit 2013?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/853981/Como+trocar+a+multim%C3%ADdia</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/853981</guid>
<pubDate>Mon, 10 Jun 2024 16:43:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: How to change language to English]]></title>
<description><![CDATA[<p>How do I change my Honda Fit language from Chinese to English</p>
<p>⟐ Answer edited março 08, 2025 at 23:32 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/890580/How+to+change+language+to+English</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/890580</guid>
<pubDate>Sat, 08 Mar 2025 23:32:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Windscreen washer not pumping but rear window does]]></title>
<description><![CDATA[<p>I have cleared the lines with compressed air and found no blockages. The rear window washer works fine. I would have thought there is only one pump. Is there 2, or do I have a faulty switch at the steering column?</p>
<p>⟐ Commented maio 31, 2022 at 9:29 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/450527/Windscreen+washer+not+pumping+but+rear+window+does</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/450527</guid>
<pubDate>Tue, 31 May 2022 09:29:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: honda fit 2002 high rpm at low speed]]></title>
<description><![CDATA[<p>Hi, i have a honda fit 2002 model with high rpm when driving at a low speed say maybe rpm of 4000 at a speed of 80km/hr. It revs so hard i can always it. It also seem to struggle to shift to the next gear when at a speed of 75-80 because i can see the rpm rev up and down until it engages the next gear after sometime. The problem is it does not show any trouble codes or light. I have tried changing the transmission twice, cleaned the throttle and the fuel tank but no change. Kindly help what could be the problem? Thanks</p>
<p>⟐ Commented janeiro 05, 2026 at 21:08 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/607739/honda+fit+2002+high+rpm+at+low+speed</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/607739</guid>
<pubDate>Mon, 05 Jan 2026 21:08:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Trailing noise under front axel]]></title>
<description><![CDATA[<p>My car has something trailing underneath when I set off looked under but I can’t see anything what could it be?</p>
<p>⟐ Commented fevereiro 08, 2022 at 7:21 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/626383/Trailing+noise+under+front+axel</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/626383</guid>
<pubDate>Tue, 08 Feb 2022 07:21:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: 2012 Honda Fit - Engine Compartment Fuse Box]]></title>
<description><![CDATA[<p>Does any other year and / or model Honda share a identical Engine Compartment Fuse Box with my 2012 Honda Fit?  Mine has 3 fuses, a 100 A for Battery, a 70 A for EPS, and a 20 A for Horn/Hazard (turn signals). The 20A fuse is blown, I can't see any way to replace just that fuse. I don't want to cobble up a blade fuse, so my only choice is to replace the entire box. I'm retired, so I don't want to pay the dealer price, so you see that means u-pull-it, the reason for my question.</p>
<p>Can anyone help me out, please?</p>
<p>Thank you for any help,</p>
<p>Jim K</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/EPnypBFfAk1K4nyO.standard" width="282" height="127" class="hasMenu hasLarge" alt="Imagem" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/EPnypBFfAk1K4nyO.huge&quot;, '', 'width=1600,height=722')" /></div>
<p>⟐ Answer accepted março 11, 2023 at 21:28 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/773124/2012+Honda+Fit+-+Engine+Compartment+Fuse+Box</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/773124</guid>
<pubDate>Sat, 11 Mar 2023 21:28:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Car will not unlock with the keys 🔐]]></title>
<description><![CDATA[<p>Car key will not work to open the car door as the key will not allow you to turn the lock?</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/793471/Car+will+not+unlock+with+the+keys+%F0%9F%94%90</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/793471</guid>
<pubDate>Mon, 22 May 2023 02:30:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: honda fit flashing drive icon and refusing to engage drive]]></title>
<description><![CDATA[<p>upon starting the car, sometimes it flashes the drive icon on the dashboard and wont engage in drive until i switch it off and start it again. how do i solve this problem.</p>
<p>⟐ Commented novembro 11, 2022 at 19:26 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/755121/honda+fit+flashing+drive+icon+and+refusing+to+engage+drive</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/755121</guid>
<pubDate>Fri, 11 Nov 2022 19:26:56 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Why is my Honda fit veer when I am on sandy road and looses control]]></title>
<description><![CDATA[<p>Why is my Honda fit veer when I am on sandy road and looses control</p>
<p>⟐ Answered julho 09, 2026 at 17:53 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/963284/Why+is+my+Honda+fit+veer+when+I+am+on+sandy+road+and+looses+control</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/963284</guid>
<pubDate>Thu, 09 Jul 2026 17:53:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Latch is stuck in locked position with Hatch open]]></title>
<description><![CDATA[<p>I have a 2010 honda fit.  Been having issues with the hatches lock for a while, but today I had it opened and locked itand it won't unlock.  So the hatch is staying open.  I have tried the key, the door lock release and just spraying it with lubricant in case it was just stuck.  No luck so far.  Any suggestions would be appreciated.</p>
<p>⟐ Answer edited abril 04, 2026 at 1:36 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/948437/Latch+is+stuck+in+locked+position+with+Hatch+open</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/948437</guid>
<pubDate>Sat, 04 Apr 2026 01:36:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: What size screw is on the throttle body clamp]]></title>
<description><![CDATA[<p>When removing the air intake box there is a throttle body clamp with a screw/bolt to tighten it. What size is that bolt?</p>
<p>⟐ Answered outubro 29, 2025 at 17:14 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/923994/What+size+screw+is+on+the+throttle+body+clamp</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/923994</guid>
<pubDate>Wed, 29 Oct 2025 17:14:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Location of ECT Sensor 1 on top of motor]]></title>
<description><![CDATA[<p>I can not find the ect location on top or side of motor. Already change ect 2 on radiator just need to figure out where #1 is located</p>
<p>⟐ Commented agosto 04, 2025 at 10:18 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/568980/Location+of+ECT+Sensor+1+on+top+of+motor</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/568980</guid>
<pubDate>Mon, 04 Aug 2025 10:18:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Why is my AC not cooling?]]></title>
<description><![CDATA[<p>Why is my AC not cooling?</p>
<p>⟐ Answered maio 29, 2025 at 19:02 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/900023/Why+is+my+AC+not+cooling</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/900023</guid>
<pubDate>Thu, 29 May 2025 19:02:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honda fit: Boot door or rear door]]></title>
<description><![CDATA[<p>My boot or rear door doesn't open</p>
<p>⟐ Answered abril 05, 2025 at 22:39 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/890198/Boot+door+or+rear+door</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/890198</guid>
<pubDate>Sat, 05 Apr 2025 22:39:23 -0700</pubDate>
</item>
</channel>
</rss>
