<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;700R4 transmission&quot;]]></title>
<link>https://pt.ifixit.com/Answers/Device/700R4_transmission?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;700R4 transmission&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Tue, 18 Aug 2026 03:08:51 -0700</pubDate>
<item>
<title><![CDATA[700R4 transmission: will not shift into 3rd just slips.]]></title>
<description><![CDATA[<p>I installed a 700r4 in my 60 chevy. It only shifts 1st to 2nd it slips when it goes to 3rd. does this have any thing to do with the TV cable not being conected?</p>
<p>⟐ Commented março 03, 2023 at 19:23 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/16806/will+not+shift+into+3rd+just+slips.</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/16806</guid>
<pubDate>Fri, 03 Mar 2023 19:23:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: Is the 700R4 interchangeable with the Turbo 350?]]></title>
<description><![CDATA[<p>Probably I will get nailed for this one, but here goes.</p>
<p>I have a 1986 Chevy K20 Pickup.  It originally came with a Turbo-Hydramatic 350 transmission.  It has a 700R4 installed now, which is shot.  Will I be able to re-install a T350 with no other wiring or tubing modifications?   Should I just be safe and find another 700r4 and throw it in?</p>
<p>Off computer topic I know, but hey do I care?  There is a big knowledge base out there.</p>
<p>Regards,</p>
<p>Frank</p>
<p>⟐ Commented setembro 06, 2025 at 18:24 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/9336/Is+the+700R4+interchangeable+with+the+Turbo+350</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/9336</guid>
<pubDate>Sat, 06 Sep 2025 18:24:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: Why wont it shift?]]></title>
<description><![CDATA[<p>Well i have more of a qiestion. I have a 1984 gmc trk with the 700 r4 and it  wont shift? There are shift silanoids and i dont no what they do but i think shift ? So i was gonna chamge.them to see if that helped i think i can save it i hope</p>
<p>⟐ Commented julho 15, 2023 at 19:04 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/92279/Why+wont+it+shift</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/92279</guid>
<pubDate>Sat, 15 Jul 2023 19:04:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: doesn't always catch 3rd when shifting from 2nd to third]]></title>
<description><![CDATA[<p>when my son leave, his truck shifts fine 1st to second, but when it comes time for 3rd it acts like it finds neutral, he lets the rpm drop down and it hooks up to 3rd fine and goes on after that. his fluild is clean and smells alright, any ideal what's up and if it could be an adjustment.</p>
<p>⟐ Answered agosto 07, 2020 at 8:44 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/27748/doesn&#039;t+always+catch+3rd+when+shifting+from+2nd+to+third</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/27748</guid>
<pubDate>Fri, 07 Aug 2020 08:44:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: Help with setting the 700r4 tv cable.]]></title>
<description><![CDATA[<p>I have a 1972 Corvette that I put a 700r4 transmission in and have a question.  I have been trying to adjust the tv cable as everyone has told me to Push down on the release tab and push the center tab in on the end of the cable, then go to full throttle and it should then set the cable to the correct setting meaning the center tab should click into place.  Mine is free and moves easy, its a new cable and its being put on an Edelbrock duel guad carb setup. However it doesn't click out at all, no movement.  Does that mean that it's set and doesn't need anything further?  Or does it mean that the throttle lever and tv cable end aren't traveling far enough?  I have went so far as to pulling on the cable end to see if it will click out and it does.</p>
<p>⟐ Answered março 30, 2019 at 8:25 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/181042/Help+with+setting+the+700r4+tv+cable.</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/181042</guid>
<pubDate>Sat, 30 Mar 2019 08:25:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: Why does my Transmission slip and buck in overdrive?]]></title>
<description><![CDATA[<p>I have a 1984 GMC 2500 vandura with a 700r4 trans mission,I have noticed that while in overdrive only,that it seems to slip out of gear, or buck</p>
<p>(sorry best way to describe) is there an external control module? or is this problem internal?</p>
<p>⟐ Answer deleted junho 11, 2012 at 0:19 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/47910/Why+does+my+Transmission+slip+and+buck+in+overdrive</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/47910</guid>
<pubDate>Mon, 11 Jun 2012 00:19:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: tranny suddenly quit shifting.]]></title>
<description><![CDATA[<p>I pulled into a parking spot. When I went to back out, the suburban would not shift into reverse. I shifted into drive and that didn't work either. I shifted back into park, and there was a noise like gear teeth slightly connnecting out of synch.</p>
<p>I shifted back into reverse, and shut the motor off...</p>
<p>what would be the most likely problem??</p>
<p>Thanks much....</p>
<p>⟐ Commented fevereiro 24, 2021 at 11:27 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/328921/tranny+suddenly+quit+shifting.</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/328921</guid>
<pubDate>Wed, 24 Feb 2021 11:27:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: Why won't my 700r4 downshift?]]></title>
<description><![CDATA[<p>t.v. cable adjusted properly, spool valve works, and governer is fine but when applying throttle car will not downshift. converter will unlock but no downshift. when slowing to a stop trans downshifts though slightly delayed. trans wasn't overheated and has less than 8000 miles.</p>
<p>⟐ Commented novembro 13, 2023 at 3:18 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/91022/Why+won&#039;t+my+700r4+downshift</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/91022</guid>
<pubDate>Mon, 13 Nov 2023 03:18:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: Why doesnt the gear box in my VVT I car engine shift to 3rd gear]]></title>
<description><![CDATA[<p>Why doesnt the gear  box in my VVT I car engine shift to 3rd gear</p>
<p>⟐ Answered maio 08, 2026 at 20:37 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/953959/Why+doesnt+the+gear+box+in+my+VVT+I+car+engine+shift+to+3rd+gear</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/953959</guid>
<pubDate>Fri, 08 May 2026 20:37:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: Transmission won’t go into reverse]]></title>
<description><![CDATA[<p>But shifts fine through all other gears.</p>
<p>⟐ Answered novembro 17, 2021 at 21:37 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/712147/Transmission+won%E2%80%99t+go+into+reverse</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/712147</guid>
<pubDate>Wed, 17 Nov 2021 21:37:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: When it gets warm it shifts too fast.]]></title>
<description><![CDATA[<p>When the transmission gets up to temperature it shifts through the gears too fast.</p>
<p>⟐ Answered janeiro 23, 2020 at 3:50 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/613138/When+it+gets+warm+it+shifts+too+fast.</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/613138</guid>
<pubDate>Thu, 23 Jan 2020 03:50:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: wont shift out of park]]></title>
<description><![CDATA[<p>my transmission wont shift out of park its a 1999 chevy pickup</p>
<p>⟐ Commented maio 27, 2019 at 15:59 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/287973/wont+shift+out+of+park</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/287973</guid>
<pubDate>Mon, 27 May 2019 15:59:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: Won't shift into gear.]]></title>
<description><![CDATA[<p>I installed a rebuilt transmission from a reputable company along with a used (freshen up with new seals)  transfercase and new standard torque converter. I put a quart in the torque converter before install, 6qts in the transmission before startup. I ran the engine till warmup checking the fluid in the process. I moved the shifter through all the gears and back. When i went to put it in park sounded like the transmission was rotating because of the grind on the parking pin. My question is the truck does not shift into gear either forward or reverse could it be the transmission or transfer case?  Do i need to readjust the TV cable? I double and triple check all connections.</p>
<p>⟐ Commented abril 25, 2019 at 8:57 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/359526/Won&#039;t+shift+into+gear.</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/359526</guid>
<pubDate>Thu, 25 Apr 2019 08:57:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: We have a BossHoss trike with shifting problems]]></title>
<description><![CDATA[<p>We have  Boss Boss trike with a 700 r 4  was running fine went t o down shift, lost all gears but neutral and reverse.Linkage fine and tranny full. Recently bought the bike so not too sure what happened.  Any feedback would be appreciated.</p>
<p>⟐ Commented março 28, 2019 at 18:45 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/336678/We+have+a+BossHoss+trike+with+shifting+problems</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/336678</guid>
<pubDate>Thu, 28 Mar 2019 18:45:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: High pitch screeching after 20mins running]]></title>
<description><![CDATA[<p>Hi all, my 200R4 starts a terrible high pitch screeching after 20mins running. Sounds like “fingernails on a blackboard” but in a circular motion. And happens in or out of gear. From an ‘85 Olds. Highish milage but newish oil/filter.  Video is on Youtube “700R4 transmission screeching”<br /></p>
<p><a href="https://www.youtube.com/watch?v=McVNzVKlJb8&amp;t=0s&amp;list=WL&amp;index=7" title="https://www.youtube.com/watch?v=McVNzVKlJb8&amp;amp;t=0s&amp;amp;list=WL&amp;amp;index=7">https://www.youtube.com/watch?v=McVNzVKl...</a></p>
<p>Thanks in advance</p>
<p>⟐ Answer accepted setembro 04, 2018 at 18:30 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/512291/High+pitch+screeching+after+20mins+running</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/512291</guid>
<pubDate>Tue, 04 Sep 2018 18:30:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: Can I use the pump from a 700r4 in 4l60e]]></title>
<description><![CDATA[<p>can i use the pump from a 700r4 in a 4l60e</p>
<p>⟐ Commented agosto 20, 2018 at 14:59 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/379392/Can+I+use+the+pump+from+a+700r4+in+4l60e</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/379392</guid>
<pubDate>Mon, 20 Aug 2018 14:59:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: all of the sudden slips in od only. all other gears work fine]]></title>
<description><![CDATA[<p>was driving my 92 vette on the highway for 3 hours and then stopped for about a half hour. Got back in car started it , put it in od and  took off. car moved at first but then started slipping so bad it almost quit moving. put gear shift in third and it took right off.</p>
<p>⟐ Answer accepted fevereiro 19, 2018 at 6:00 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/357888/all+of+the+sudden+slips+in+od+only.+all+other+gears+work+fine</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/357888</guid>
<pubDate>Mon, 19 Feb 2018 06:00:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: My truck want change into third]]></title>
<description><![CDATA[<p>I changed the transfer case and now the transmisson want change into third what is wrong</p>
<p>⟐ Answer accepted novembro 07, 2017 at 16:14 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/257094/My+truck+want+change+into+third</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/257094</guid>
<pubDate>Tue, 07 Nov 2017 16:14:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: I. Have problem but mine is a 90. Silverado]]></title>
<description><![CDATA[<p>I. Have problem but mine is a 90. Silverado 4x4 slips in 3rd gear</p>
<p>⟐ Answered junho 18, 2017 at 15:39 GMT-7</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/405948/I.+Have+problem+but+mine+is+a+90.+Silverado</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/405948</guid>
<pubDate>Sun, 18 Jun 2017 15:39:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[700R4 transmission: Why is my 700R4 completely frozen?]]></title>
<description><![CDATA[<p>After sitting for a month or so, my 700R4 transmission is completely locked up. I start the engine, but when I put it in gear, it slams into gear violently and the engine dies regardless of the RPM. I jacked the rear wheels off the ground and it does the same thing without the wheels even slightly turning. I can rotate the wheels quite easily by hand while on jack stands.</p>
<p>Any thoughts on this greatly appreciated.</p>]]></description>
<link>https://pt.ifixit.com/Answers/View/893498/Why+is+my+700R4+completely+frozen</link>
<guid isPermaLink="false" >https://pt.ifixit.com/Answers/View/893498</guid>
<pubDate>Thu, 27 Mar 2025 12:55:58 -0700</pubDate>
</item>
</channel>
</rss>
