Ir para o conteúdo principal
Samsung Galaxy S7 Home Button Replacement
O que você precisa
Instruções em vídeo
Conclusão
MovilOne
Membro desde: 06/17/14
2.480 Reputação
Autoria de 14 guias
5 comentários
Hi,
Recently screen replaced with new homebutton - now fingerprint sensor is only giving error, any way to fix this?
Phone is rooted and has cust.firmware installed.
Try to fix :
factory defaults
reboots
cleared cache
Thanks for your reply!
Patrick Pieck - Responder
Thanks for you info.
www.movilone.es
MovilOne - Responder
hi finger scanner is not working but home button is work please suggest me
Shamim Akhtar - Responder
its cause the fingerprint sensor is synced with your logic board, you would have to write a script for it to work… which in that case would make you the first one to do so
Eric Touzin -
I need to replace the board of charger port with the module antenne, so I need to disamble the screen and don't know a what temperature I have to put the blower to not damage the LCD screen.
Joe Morel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 17,832
