Ir para o conteúdo principal
Nintendo Wii Remote Front Cover Plate and Batteries Replacement
O que você precisa
  1. Nintendo Wii Remote Front Cover Plate and Batteries Replacement, Front Cover Plate and Batteries: passo 1, imagem 1 %32 Nintendo Wii Remote Front Cover Plate and Batteries Replacement, Front Cover Plate and Batteries: passo 1, imagem 2 %32
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: passo 2, imagem 1 %32
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: passo 3, imagem 1 %32
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: passo 4, imagem 1 %32 Nintendo Wii Remote Front Cover Plate and Batteries Replacement: passo 4, imagem 2 %32
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
Conclusão
36 outras pessoas executaram este guia.
Emily
Membro desde: 04/14/13
1.509 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-44, Amido Spring 2013 Membro de Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
Membros da 4
Autoria de 26 guias
4 comentários
Worked! Had to solder the tab to contact the battery which had broken. Saved $50.00.
Graham Poor - Responder
The Tools section lists a Tri-Point Y1 Screwdriver but the guide mentions a Tri-Wing Y1 Screwdriver. This could cause people to purchase the wrong item.
iFixit’s guides seem to be based on the original Wii controller, model RVL-003. I’m not sure if Nintendo has changed fasteners for subsequent versions but the Wii MotionPlus Controller, model RVL-036, uses a Tri-Wing Y0 screw.
kivrin - Responder
@kivrin Thanks for your comment. I’m pretty sure it should say tri-point, not tri-wing. I’ll update the instructions. Tri-wing screws have a more twisted/triangular form factor, like this.
Jeff Suovanen -
My controller (the original) had three tri-wing screws and one philips. Not sure why. Had to re-solder the negative battery terminal as it came off the bottom of the ‘top’ (faces bottom) of the board.
audvare - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 24
Últimos 7 dias: 228
Últimos 30 dias: 1,274
Duração total: 103,364
