Ir para o conteúdo principal
TRIC Guitar Case Plastic Hinge Replacement
O que você precisa
  1. TRIC Guitar Case Plastic Hinge Replacement, Plastic Hinge: passo 1, imagem 1 %32 TRIC Guitar Case Plastic Hinge Replacement, Plastic Hinge: passo 1, imagem 2 %32
    • Confirm that the hinge is actually broken or split. Indeed, one of my hinges is broken.
    • Sometimes a broken hinge can be accompanied by a second broken hinge since the stress of one broken hinge begins to break the second one.
  2. TRIC Guitar Case Plastic Hinge Replacement: passo 2, imagem 1 %32 TRIC Guitar Case Plastic Hinge Replacement: passo 2, imagem 2 %32 TRIC Guitar Case Plastic Hinge Replacement: passo 2, imagem 3 %32
    • Order a replacement hinge from your local guitar store, or directly contact Godin for replacement at info@godinguitars.com
    • My supplier/brand was "Godin", the model was "TRIC Case Hinges", and the Color was "GREY".
    • Here's what the new hinge looks like next to the old hinge.
    • Here's what the new hinge looks like next to a human foot in the distance.
  3. TRIC Guitar Case Plastic Hinge Replacement: passo 3, imagem 1 %32
    • Using a blow dryer (or heat gun) to warm up the glues holding the old hinge in place.
    • This heating process took at least 15 minutes for me with a blow dryer.
  4. TRIC Guitar Case Plastic Hinge Replacement: passo 4, imagem 1 %32 TRIC Guitar Case Plastic Hinge Replacement: passo 4, imagem 2 %32 TRIC Guitar Case Plastic Hinge Replacement: passo 4, imagem 3 %32
    • As the glue starts to soften, you can pry the hinge pieces off with a tool like a Swiss Army knife. If it is still stuck on solid, keep blow drying it.
  5. TRIC Guitar Case Plastic Hinge Replacement: passo 5, imagem 1 %32
    • The hinge piece comes off! Fantastic.
  6. TRIC Guitar Case Plastic Hinge Replacement: passo 6, imagem 1 %32 TRIC Guitar Case Plastic Hinge Replacement: passo 6, imagem 2 %32 TRIC Guitar Case Plastic Hinge Replacement: passo 6, imagem 3 %32
    • Repeat for the other hinge piece: blow dry, soften the glue, pry off.
    • Hinge pieces shown side by side: new hinge on the left, old hinge on the right.
  7. TRIC Guitar Case Plastic Hinge Replacement: passo 7, imagem 1 %32 TRIC Guitar Case Plastic Hinge Replacement: passo 7, imagem 2 %32 TRIC Guitar Case Plastic Hinge Replacement: passo 7, imagem 3 %32
    • Use Shoe Goo to fill the cavity where the old hinge was previously. WARNING: do not use traditional hot glue gun because it dries up too fast before you even get a chance to put the new hinge on.
    • Put the new hinge in the cavities and apply some pressure to make it sink deep into the hinge cavity.
  8. TRIC Guitar Case Plastic Hinge Replacement: passo 8, imagem 1 %32 TRIC Guitar Case Plastic Hinge Replacement: passo 8, imagem 2 %32
    • Fold the guitar case closed and clamp the clips to close it tight. Push the two sides to let excess Shoe Goo ooze out (that sounds so nice!).
    • Put a sack of rice or something heavy on the guitar case to let the glue solidify and dry overnight.
    • Wipe off any excess Shoe Goo that has oozed out with a paper towel or tissue.
  9. TRIC Guitar Case Plastic Hinge Replacement: passo 9, imagem 1 %32
    • After the Shoe Goo has dried up, your TRIC case is like new! So great!
    • To prevent future cracking, I may apply some sort of strong tape to the inside of the hinge.
Conclusão
Transport your guitar with peace-of-mind.
Silas
Membro desde: 09/28/13
121 Reputação
Autoria de 1 guia
7 comentários
Silas-
Thanks for posting this.
"Where can I order the hinges from? I checked with my local Guitar Center, and they were clueless.
Also, my TRIC case handle is cracked, and on its last legs-any hints on fixing it?
Jim B.
jambre1 - Responder
I contacted the Seagull company(info@seagullguitars.com)and the hinges were sent out, made the repair last night, works like a charm!- Thanks again, Silas-
Jim B.
jambre1 - Responder
hey jim
sorry i did not see you message until now! glad your diy repair worked out and that my guide helped you out too! take care!
Silas -
it works... Thanks Silas :). And I have one question that whether I can buy the canvas cover for that case or not. Thank you!!
Shine Nay Lin Oo - Responder
I don't know whether you can buy just the canvas cover these days. I found this link for you online! https://store.godinguitars.com/usa/35-ca... Looks like they sell the canvas cover with the foam case together.
Silas -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 3,983
