Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua MacBook Pro 13" Touch Bar 2017, use o nosso manual de serviço.
  1. MacBook Pro 13" Touch Bar 2017 Teardown, MacBook Pro 13" Touch Bar 2017 Teardown: passo 1, imagem 1 %32 MacBook Pro 13" Touch Bar 2017 Teardown, MacBook Pro 13" Touch Bar 2017 Teardown: passo 1, imagem 2 %32
    • Gotta love that new Mac smell, but just how new is this Pro? Get a whiff of these specs:
    • 13.3” LED-backlit IPS Retina display with 2560 × 1600 resolution (227 dpi), P3 wide color gamut
    • 3.1 GHz Kaby Lake dual-core Intel Core i5 (Turbo Boost up to 3.5 GHz)
    • 8 GB of 2133 MHz LPDDR3 SDRAM
    • 256 GB PCIe-based SSD
    • Integrated Intel Iris Plus Graphics 650
    • Four Thunderbolt 3 (USB-C) ports and 3.5 mm headphone port
    • 802.11ac Wi-Fi and Bluetooth 4.2
  2. MacBook Pro 13" Touch Bar 2017 Teardown: passo 2, imagem 1 %32 MacBook Pro 13" Touch Bar 2017 Teardown: passo 2, imagem 2 %32 MacBook Pro 13" Touch Bar 2017 Teardown: passo 2, imagem 3 %32
    • Thanks to prior experience, we've got the obnoxious suction-prying-sliding maneuver down, and we pop this little guy open in no time.
    • Once the oyster is cracked, and the pearl revealed, we get some serious deja vu.
    • Compare the MacBook Pro 13" Touch Bar 2017 (second)...
    • ... to the MacBook Pro 13" Touch Bar 2016 (third).
    • Everything looks pretty much the same to us, right down to the 49.2 Wh battery.
    • The only difference we spot is the finish on the fans. Looks like the 4K iMac got the real refresh juice this year.
  3. MacBook Pro 13" Touch Bar 2017 Teardown: passo 3, imagem 1 %32 MacBook Pro 13" Touch Bar 2017 Teardown: passo 3, imagem 2 %32
    • We pick some cuffs out of this notebook and turn them into some mustaches. Here are the secrets within:
    • Intel Core i5-7267U processor with Intel Iris Plus Graphics 650
    • Intel® JHL6540 Thunderbolt™ 3 Controller
    • SanDisk SDRQKBDC4 064G 64 GB NAND flash memory (x2 for a total of 128 GB on this side of the board)
    • Samsung K4E6E304EB-EGCG LPDDR3 DRAM (4 x 2 GB for 8 GB total)
    • Texas Instruments SN650839 power management, and TI/Stellaris LM4FS1EH SMC Controller (replacement codename for TM4EA231)
    • SK Hynix H9CKNNN4GTATMR-NTH memory with custom SSD controller layered underneath (likely)
    • Murata/Apple 339S00056 Wi-Fi Module
  4. MacBook Pro 13" Touch Bar 2017 Teardown: passo 4, imagem 1 %32
    • On the opposite side we find:
    • 2x SanDisk SDRQKBDC4 064G 64 GB NAND flash storage (as seen in the 2016 Escape Edition's removable SSD)—bringing the total to 256 GB
    • APL1023/343S00736 (likely the custom Apple T1 chip that pairs with the Touch Bar) and (Apple?) 338S00193-A1 (probably both power management)
    • 2x Texas Instruments TI CD3215C00 USB-C controller (+2 on the other side)
    • Intersil ISL95828 PWM controller for Intel CPUs (likely)
    • Texas Instruments HD3SS215 6.0 Gbps HDMI DisplayPort 2:1/1:2 Differential Switch
    • Macronix MX25L6473EZNI-10G Serial Flash Memory
    • NXP 66V10 (PN66V ?) NFC controller, containing Secure Element 008 and NXP PN549 (as seen in the iPhone 6s)
  5. MacBook Pro 13" Touch Bar 2017 Teardown: passo 5, imagem 1 %32 MacBook Pro 13" Touch Bar 2017 Teardown: passo 5, imagem 2 %32
    • IC Identification, continued:
    • Texas Instruments TPS51980A power management and likely Renesas battery charger
    • Texas Instruments TPS51916 DDR memory power supply
    • Cirrus Logic/Analog Devices audio codec and amplifier (likely)
    • Texas Instruments TMPxxx temperature sensor (assumption)
    • Vishay SiC635 power stage
    • Serial Flash and EEPROM Memory (likely)
    • Apple SSD power management (assumption)
  6. MacBook Pro 13" Touch Bar 2017 Teardown: passo 6, imagem 1 %32
  7. Considerações finais
    • The trackpad can be removed without first removing the battery.
    • Proprietary pentalobe screws continue to make working on the device unnecessarily difficult.
    • The battery assembly is entirely, and very solidly, glued into the case, thus complicating replacement.
    • The processor, RAM, and flash memory are soldered to the logic board.
    • The Touch Bar adds a second, difficult to replace, screen to damage.
    • The Touch ID sensor doubles as the power switch, and is paired with the T1 chip on the logic board. Fixing a broken power switch may require help from Apple, or a new logic board.
    Índice de reparabilidade
    Reparabilidade 1 de 10
    (10 é o mais fácil de reparar)
34 comentários
Also, good luck getting your data off of those pci-e style hard drives.
j0vian - Responder
There is a special boot mode in which the Mac basically acts like a network connected drive (NAS)
Mining15 -
I'll stick with my repairable and upgrade friendly MacBook Pro 2012 thanks.
Apple lost a winning edge when they removed user serviceable from their vernacular.
Justin - Responder
I’m inclined to agree.
This will very likely be my last Mac.
When did Apple decide to play games like MS used to?
Corey DeLasaux -
You should do an in-depth analysis of they new keyboard, and see if there are actual structural differences between the 2016 keyboard and the new 2017 one, and if so provide some pictures.
Johannes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 20
Últimos 7 dias: 240
Últimos 30 dias: 1,050
Duração total: 332,701
