Ir para o conteúdo principal
How to Embed a Guide or Teardown
  1. How to Embed a Guide or Teardown, View teardown or guide: passo 1, imagem 1 %32
    • Navigate to the teardown or guide page that you would like to embed.
  2. How to Embed a Guide or Teardown, Select language (optional): passo 2, imagem 1 %32 How to Embed a Guide or Teardown, Select language (optional): passo 2, imagem 2 %32 How to Embed a Guide or Teardown, Select language (optional): passo 2, imagem 3 %32
    • If you wish to embed the guide or teardown in a different language than the one currently selected:
    • Click on the language icon in the upper right of the header bar.
    • In the pop-up window, click to select the desired language.
    • The site will load the page in the selected language.
  3. How to Embed a Guide or Teardown, Create embed code: passo 3, imagem 1 %32 How to Embed a Guide or Teardown, Create embed code: passo 3, imagem 2 %32
    • Click the "Options" button on the upper-righthand corner of the page.
    • Select "Embed This Guide" from the dropdown menu.
  4. How to Embed a Guide or Teardown, Copy embed code: passo 4, imagem 1 %32 How to Embed a Guide or Teardown, Copy embed code: passo 4, imagem 2 %32
    • A pop-up window will appear with an HTML embed code and a preview of your embedded guide.
    • Select the size you wish the embedded guide to be.
    • Copy the auto-generated HTML code.
  5. How to Embed a Guide or Teardown, Embed guide on your site: passo 5, imagem 1 %32 How to Embed a Guide or Teardown, Embed guide on your site: passo 5, imagem 2 %32
    • Paste your HTML code into the site's text box.
    • Enjoy your embedded guide!
Linha de Chegada
11 outras pessoas executaram este guia.
Julia
Membro desde: 02/09/12
2.015 Reputação
Autoria de 1 guia
3 comentários
Fix blinking screen on startup
Richard Woolwine - Responder
Is there an API to access contents?
Luca Orlandi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 62
Duração total: 3,922
