Ir para o conteúdo principal
iPhone X Disassembly
O que você precisa
Vídeo de Apresentação
  1. iPhone X Disassembly, Turn off the phone and remove SIM Card: passo 1, imagem 1 %32 iPhone X Disassembly, Turn off the phone and remove SIM Card: passo 1, imagem 2 %32
    • Press the wake button and volume down button to turn off the phone.
  2. iPhone X Disassembly, Open the phone: passo 2, imagem 1 %32 iPhone X Disassembly, Open the phone: passo 2, imagem 2 %32 iPhone X Disassembly, Open the phone: passo 2, imagem 3 %32
    • Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will allow the phone to be opened more easily.
  3. iPhone X Disassembly, Remove the iPhone X OLED screen: passo 3, imagem 1 %32 iPhone X Disassembly, Remove the iPhone X OLED screen: passo 3, imagem 2 %32 iPhone X Disassembly, Remove the iPhone X OLED screen: passo 3, imagem 3 %32
    • Undo 5 screws shown in the picture below with a tripoint #Y000 screwdriver
    • These screws are all different sized so keep track of where they go
    • Release the battery/LCD screen/digitizer/ear speaker connectors with a spudger.
  4. iPhone X Disassembly, Remove the ear speaker: passo 4, imagem 1 %32 iPhone X Disassembly, Remove the ear speaker: passo 4, imagem 2 %32
    • Undo 3 Y000 screws and heating the flex cable with a heat gun, we can remove the ear speaker easily
  5. iPhone X Disassembly, Remove rear-facing cameras.: passo 5, imagem 1 %32
    • Remove the 2 Phillips #PH00 screws and remove the metal plate, release the rear cameras connectors.
    • These screws are also different sizes
  6. iPhone X Disassembly, Remove motherboard.: passo 6, imagem 1 %32 iPhone X Disassembly, Remove motherboard.: passo 6, imagem 2 %32
    • Release all connectors on the motherboard with a spudger
    • Undo 3 Phillips #PH00 screws on the mother board then we can take out the mother board.
  7. iPhone X Disassembly, Remove Loudspeaker and Taptic engine: passo 7, imagem 1 %32 iPhone X Disassembly, Remove Loudspeaker and Taptic engine: passo 7, imagem 2 %32 iPhone X Disassembly, Remove Loudspeaker and Taptic engine: passo 7, imagem 3 %32
    • Undo 8 screws on the retaining plate then remove the plate taking care to not break the small connector on the plate that connects just under the taptic engine
    • Remove the loud speaker and the taptic engine.
  8. iPhone X Disassembly, Remove battery: passo 8, imagem 1 %32 iPhone X Disassembly, Remove battery: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pulling out 4 battery adhesives with a tweezers then we can remove the battery.
  9. iPhone X Disassembly, Remove front-facing camera: passo 9, imagem 1 %32 iPhone X Disassembly, Remove front-facing camera: passo 9, imagem 2 %32
    • Heating the front facing camera with a heat gun will make it easily to be removed
  10. iPhone X Disassembly, Remove the charging port and antenna: passo 10, imagem 1 %32 iPhone X Disassembly, Remove the charging port and antenna: passo 10, imagem 2 %32 iPhone X Disassembly, Remove the charging port and antenna: passo 10, imagem 3 %32
    • Release 4 screws on the frame shown in the picture
    • Heating the charging port flex cable then we can remove it easily
  11. iPhone X Disassembly, Remove Wi-Fi antenna: passo 11, imagem 1 %32 iPhone X Disassembly, Remove Wi-Fi antenna: passo 11, imagem 2 %32 iPhone X Disassembly, Remove Wi-Fi antenna: passo 11, imagem 3 %32
    • Release 7 screws on the Wi-Fi flex cable
    • Heating the flex cable with a heat gun make it easier to be removed
  12. iPhone X Disassembly, Remove power button flex cable: passo 12, imagem 1 %32 iPhone X Disassembly, Remove power button flex cable: passo 12, imagem 2 %32 iPhone X Disassembly, Remove power button flex cable: passo 12, imagem 3 %32
    • Release 3 screws on the power button
    • Heating the flex cable with a heat gun then it can be removed easily
Conclusão
129 outras pessoas executaram este guia.
Mandy
Membro desde: 12/05/14
9.518 Reputação
Autoria de 9 guias
25 comentários
excellent guide!!!
Andy Lee - Responder
What About the backside ? I heard that when the backside is shattered, it’s almost impossible to repair, because of the glue that holds the backside and parts together ?
Arnoud - Responder
Hi avdk, we don’t tear down the back glass but we will pay attention to this question. If there is a definite answer, I will reply to you .Thank you.
Mandy -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 44
Últimos 7 dias: 260
Últimos 30 dias: 1,149
Duração total: 210,939
