Ir para o conteúdo principal
iPhone X SIM Card Replacement
O que você precisa
  1. iPhone X  SIM Card  Replacement, SIM Card: passo 1, imagem 1 %32 iPhone X  SIM Card  Replacement, SIM Card: passo 1, imagem 2 %32 iPhone X  SIM Card  Replacement, SIM Card: passo 1, imagem 3 %32
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located near the side button on the edge of the iPhone.
    • Press firmly to eject the tray.
  2. iPhone X  SIM Card  Replacement: passo 2, imagem 1 %32 iPhone X  SIM Card  Replacement: passo 2, imagem 2 %32
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
Conclusão
To re-assemble, just reinsert the SIM card.
37 outras pessoas executaram este guia.
nicolay.94
Membro desde: 03/09/17
3.957 Reputação
Autoria de 2 guias
2 comentários
Great guide. After using smartphones for a decade now I know how to put a Sim card in my iPhone.
Kokab Asghar - Responder
ソフトバンクをsimフリーにしたい
浜松金太郎 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 25
Últimos 7 dias: 238
Últimos 30 dias: 863
Duração total: 69,206
