Introdução
Follow the steps in this guide to replace the Wi-Fi diversity antenna in your iPhone 6s.
O que você precisa
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
Ferramenta utilizada nesse passo:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket, of the following lengths:
One 2.9 mm screw
One 2.2 mm screw
Remove the following four Phillips screws securing the display cable bracket:
Three 1.2 mm screws
One 2.8 mm screw
Use the point of a spudger to lift and disconnect the antenna cable from the bottom end of the logic board.
Remove the tape covering the antenna cable on the edge of the speaker.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our iPhone 6s Answers community for troubleshooting help.
41 outras pessoas executaram este guia.
6 comentários
You guys are awesome. Thank you
Thank you for the guide! I followed and completed the steps however my Wifi is still greyed out and doesn't let me turn it on
This guide has been updated! Unnecessary steps have been trimmed.
Does the Wi-Fi Diversity antenna also function as the Bluetooth antenna for iPhone 6s? If not, how does one replace the iPhone 6s Bluetooth antenna?
Did you ever get an answer? I would like to know that too
