Ir para o conteúdo principal
Xbox 360 Bottom Vent Replacement
O que você precisa
  1. Xbox 360 Bottom Vent Replacement, Bottom Vent: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Xbox 360 Opening Tool
    Comprar
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
  2. Xbox 360 Bottom Vent Replacement: passo 2, imagem 1 %32 Xbox 360 Bottom Vent Replacement: passo 2, imagem 2 %32 Xbox 360 Bottom Vent Replacement: passo 2, imagem 3 %32
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
  3. Xbox 360 Bottom Vent Replacement: passo 3, imagem 1 %32 Xbox 360 Bottom Vent Replacement: passo 3, imagem 2 %32
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
  4. Xbox 360 Bottom Vent Replacement: passo 4, imagem 1 %32 Xbox 360 Bottom Vent Replacement: passo 4, imagem 2 %32
    • Repeat the same process to release the two center clips on the bottom vent.
  5. Xbox 360 Bottom Vent Replacement: passo 5, imagem 1 %32 Xbox 360 Bottom Vent Replacement: passo 5, imagem 2 %32
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
  6. Xbox 360 Bottom Vent Replacement: passo 6, imagem 1 %32
    • Remove the bottom vent from the 360.
Conclusão
68 outras pessoas executaram este guia.
Um comentário
cool thanks for the tip
exavier smith - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 84
Duração total: 28,169
