Ir para o conteúdo principal
System76 Serval WS Cooling Fan Replacement
O que você precisa
  1. System76 Serval WS Cooling Fan Replacement, Cooling Fan: passo 1, imagem 1 %32
    • Unplug the power supply and remove the battery from the device before proceeding.
    • Unscrew and remove the 4 screws circled in red. Then remove the plastic bottom panel.
  2. System76 Serval WS Cooling Fan Replacement: passo 2, imagem 1 %32 System76 Serval WS Cooling Fan Replacement: passo 2, imagem 2 %32
    • Remove the numbered screws in order to safely remove the heatsink
    • Remove the heatsink to access the cooling fans.
    • During reassembly, make sure to tighten the heatsink screws in the order indicated by the labeled numbers.
  3. System76 Serval WS Cooling Fan Replacement: passo 3, imagem 1 %32
    • Unscrew and remove the screws circled in red, 3 screws per fan.
    • Next unplug the 4-pin power connectors, marked in orange squares.
    • Remove the cooling fans by lifting them up and out of the casing.
  4. System76 Serval WS Cooling Fan Replacement: passo 4, imagem 1 %32 System76 Serval WS Cooling Fan Replacement: passo 4, imagem 2 %32
    • Plug in the 4-pin power connectors of the new fans.
    • Insert and tighten 3 screws per fan.
    • If needed, clean off the old thermal paste from the CPU, GPU, and heatsink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste before reassembly.
    • Clean the dust from the heatsink fins.
Conclusão
Oliver Anderson
Membro desde: 03/26/19
289 Reputação
Autoria de 3 guias
Equipe
Um comentário
What model of fan would one buy to replace this?
CrustyTrombone - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 14
Duração total: 628
