Ir para o conteúdo principal
Nokia Lumia 635 630 Display Assembly Replacement with Frame
O que você precisa
Vídeo de Apresentação
  1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: passo 1, imagem 1 %32 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: passo 1, imagem 2 %32 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: passo 1, imagem 3 %32
    • Remove the battery and any SIM and memory cards.
    • Remove the black sticker at the bottom side of the phone.
  2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 2, imagem 1 %32 Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 2, imagem 2 %32 Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 2, imagem 3 %32
    • Use a screwdriver Torx T4 and remove the 7x screws.
    • There are two other smaller screws with the same head size – remove them as well.
  3. Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 3, imagem 1 %32 Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 3, imagem 2 %32 Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 3, imagem 3 %32
    • Lift the rear bezel and unhook the display assembly flex cable.
    • Don't use a metal tool for disconnecting the flex cable. There are many small elements near the connectors. You could break them. If you don't have a suitable tool just use your nails.
    • Now we have to transfer the earpiece.
  4. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: passo 4, imagem 1 %32 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: passo 4, imagem 2 %32 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: passo 4, imagem 3 %32
    • Put the earpiece on the new display assembly and start with reassembling.
Conclusão
17 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.647 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.498 guias
2 comentários
Where do i get the part replacements from to replace the screen and what not?
Nathaniel Ogungbuyi - Responder
Großes Lob an Nokia, das ist noch ein super zu öffnendes Smartphone gewesen! Touchdisplay tauschen war einfach.
Tale Spinner - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 10,344
