Ir para o conteúdo principal
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement
O que você precisa
  1. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement, Lower Case: passo 1, imagem 1 %32
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement: passo 2, imagem 1 %32
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement, RAM: passo 3, imagem 1 %32 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement, RAM: passo 3, imagem 2 %32
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
Conclusão
96 outras pessoas executaram este guia.
Um comentário
How is this easier than removing a drive? Its both relatively easy. Otherwise good guides.
Jr. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 40,987
