Ir para o conteúdo principal
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement
O que você precisa
  1. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement, Lower Case: passo 1, imagem 1 %32
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Lower Case Replacement: passo 2, imagem 1 %32
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Conclusão
26 outras pessoas executaram este guia.
Um comentário
These two little plastic clamps on the upper case that snap on/off the lower case broke. I was looking through the store for replacements but I couldn't find any. Does anyone know where I can get these?
hmalissa - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 15,723
