Ir para o conteúdo principal
MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement
O que você precisa
Vídeo de Apresentação
  1. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 2, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 2, imagem 2 %32
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement, Battery Connection: passo 3, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement, Battery Connection: passo 3, imagem 2 %32
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 4, imagem 1 %32
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement, Fan: passo 5, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement, Fan: passo 5, imagem 2 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement, Fan: passo 5, imagem 3 %32
    • Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  6. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 6, imagem 1 %32
    • Remove the following three screws securing the fan to the logic board:
    • One 7.2 mm T6 Torx screw
    • Two 5.3 mm T6 Torx screws
  7. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 7, imagem 1 %32
    • Lift the fan out of its recess in the logic board, minding its cable that may get caught.
  8. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement, Logic Board: passo 8, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement, Logic Board: passo 8, imagem 2 %32
    • Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
    • Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
  9. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 9, imagem 1 %32
    • Disconnect the camera cable from the logic board.
    • The camera cable lifts straight away from the logic board. If your cable feels fragile, use a spudger to pry up on the small metal tabs on each side of the connector head to disconnect the cable.
  10. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 10, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 10, imagem 2 %32
    • Disconnect the following four cables:
    • AirPort/Bluetooth cable
    • Optical drive cable
    • Hard drive cable
    • Trackpad cable
    • To disconnect the cables, use the flat end of a spudger to pry their connectors up from the sockets on the logic board.
  11. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 11, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 11, imagem 2 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 11, imagem 3 %32
    • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
    • The cable may be difficult to insert. If you are having trouble, temporarily attach a piece of tape to the cable to help you guide the cable into the socket.
  12. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 12, imagem 1 %32
    • If present, remove the small strip of black tape covering the keyboard backlight cable socket.
  13. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 13, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 13, imagem 2 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 13, imagem 3 %32
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
  14. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 14, imagem 1 %32
    • Use the flat end of a spudger to pry the sleep sensor/battery indicator connector up from its socket on the logic board.
  15. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 15, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 15, imagem 2 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 15, imagem 3 %32
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  16. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 16, imagem 1 %32
    • Remove the following nine screws:
    • Five 3.6 mm T6 Torx screws
    • Two 4.3 mm T6 Torx screws
    • Two 7.2 mm T6 Torx screws
    • In some models the screws may be slightly shorter as follows:
    • Five 3.0 mm T6 screws
    • Two 3.6 mm T6 screws
    • Two 6.7 mm T6 screws
  17. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 17, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 17, imagem 2 %32
    • Remove the following two screws:
    • One 8.6 mm Phillips screw
    • One 5.5 mm Phillips screw
    • Remove the display data cable retainer from the upper case.
  18. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 18, imagem 1 %32
    • Use the tip of a spudger to gently peel the microphone off the adhesive securing it to the upper case.
  19. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 19, imagem 1 %32
    • Minding the many connectors near its edges, lift the logic board from the end nearest the optical drive.
    • Without flexing the board, maneuver it out of the upper case, minding the flexible connection to the DC-In board that may get caught in the upper case.
    • Remove the logic board.
  20. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement, Upper Case: passo 20, imagem 1 %32
    • One 5.6 mm Tri-point screw
    • One 13 mm Tri-point screw
  21. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 21, imagem 1 %32
    • Carefully peel the battery warning label off the upper case between the battery and the optical drive.
    • Do not remove the label from the battery.
  22. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 22, imagem 1 %32
    • Use the attached plastic pull tab to help remove the battery from the upper case.
  23. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 23, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 23, imagem 2 %32
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws will remain captive to the hard drive bracket.
    • Remove the hard drive bracket.
    • The hard drive bracket may be firmly seated against the upper case.
  24. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 24, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 24, imagem 2 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 24, imagem 3 %32
    • Use the attached pull tab to lift the hard drive out of the upper case.
    • Pull the hard drive cable away from the body of the hard drive.
    • Remove the hard drive.
  25. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 25, imagem 1 %32
    • Remove the following four screws:
    • Two 3 mm Phillips screws
    • Two 9.7 mm Phillips screws
  26. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 26, imagem 1 %32
    • Carefully peel up the thin IR sensor/sleep LED ribbon cable from the adhesive securing it to the upper case.
  27. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 27, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 27, imagem 2 %32
    • Pull the front hard drive bracket containing the IR sensor/sleep LED away from the front edge of the upper case.
    • Remove the hard drive cable.
  28. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 28, imagem 1 %32
    • Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
    • De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
  29. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 29, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 29, imagem 2 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 29, imagem 3 %32
    • Disconnect the four antenna connectors boxed in red in the first picture.
    • To do so, use the tip of a spudger to pry their connectors up from the sockets on the AirPort/Bluetooth board.
    • De-route each of the cables from their channels in the AirPort/Bluetooth bracket.
  30. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 30, imagem 1 %32
    • Remove the following five screws:
    • Two 10.3 mm Phillips screws
    • Two 3.1 mm Phillips screws
    • One 5 mm Phillips screw
  31. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 31, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 31, imagem 2 %32
    • Pull the AirPort/Bluetooth assembly and the Subwoofer upward near the center of the side of the optical drive until they clear each other.
    • Remove the AirPort/Bluetooth board assembly.
  32. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 32, imagem 1 %32
    • Remove the three 2.7 mm Phillips screws securing the optical drive to the upper case.
  33. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 33, imagem 1 %32
    • Lift the optical drive from the edge nearest the display and remove it from the upper case.
  34. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 34, imagem 1 %32
    • Peel the right speaker cable off the upper case.
  35. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 35, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 35, imagem 2 %32
    • Use a plastic opening tool or another thin prying object to carefully pry the right speaker up from the adhesive securing it to the upper case.
    • Start prying up from the edge of the right speaker nearest the display. Starting from the other side may damage one of the antennas.
    • Pry up along the edge of the right speaker until it is separated from the upper case.
  36. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 36, imagem 1 %32
    • Pull the right speaker out from under the optical drive opening.
  37. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 37, imagem 1 %32
    • Remove two of the three 6 mm T8 Torx screws securing the right side of the display to the upper case.
    • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
  38. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 38, imagem 1 %32
    • Remove the small piece of foam tape covering the left display hinge screws.
  39. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 39, imagem 1 %32
    • Remove two of the three 6 mm T8 Torx screws securing the left side of the display to the upper case.
  40. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 40, imagem 1 %32
    • Open your MacBook Pro so the display is perpendicular to the upper case.
    • Place your opened MacBook Pro on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower display bracket.
  41. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 41, imagem 1 %32
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
  42. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 42, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 42, imagem 2 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 42, imagem 3 %32
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
    • Upper case remains.
  43. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement, Upper Case: passo 43, imagem 1 %32
    • Remove the four 1.2 mm Phillips screws highlighted in red.
  44. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 44, imagem 1 %32
    • Carefully dislodge the edge of the trackpad closest to the keyboard from its recess in the upper case by pushing it away from the brackets attached to the upper case.
    • De-route the trackpad cable through its slot cut into the upper case.
  45. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 45, imagem 1 %32
    • Pull the trackpad away from the outer edge of the upper case.
    • Remove the trackpad and set it aside.
  46. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 46, imagem 1 %32
    • In the following steps, you will be working on your new upper case.
    • Use a T6 Torx screwdriver to loosely install the 1.1 mm set screw included with your new upper case into its tapped hole near the middle of the trackpad opening on your new upper case.
    • Only tighten it about one turn for now.
  47. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 47, imagem 1 %32 MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 47, imagem 2 %32
    • Carefully insert the cable from your old trackpad through its slot cut into your new upper case.
    • Use one hand to hold the trackpad cable in place as you insert the two retaining tabs on the outer edge of the trackpad under the lip on the upper case.
    • Pull the trackpad cable as you seat the trackpad into its void in your new upper case.
  48. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 48, imagem 1 %32
    • Insert a 1.2 mm Phillips screw into each of the outer holes drilled into the trackpad (two screws total).
    • You'll install the rest in a bit.
    • Tighten the screws, then back them out about a quarter turn to aid in aligning your trackpad during the next few steps.
  49. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 49, imagem 1 %32
    • While continually trying to click your trackpad, gently tighten the T6 Torx set screw until the clicks return to their factory "feel."
    • You can tell when the screw is tightened just right by the noise it makes when the trackpad clicks. If the set screw is too loose, the trackpad will have excessive play before it clicks. If it is too tight, the trackpad will click too easily and won't make the characteristic loud mouse clicking noise.
  50. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 50, imagem 1 %32
    • Next, flip your upper case over so the keyboard side is facing up.
    • Align the trackpad so it is centered in its hole cut into the upper case.
  51. MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement: passo 51, imagem 1 %32
    • Tighten the outer two screws along the inner edge of the trackpad and check the alignment of it on the outer side of the upper case.
    • If its alignment looks good, install the rest of the Phillips screws along the inner edge of the trackpad.
    • Before reassembling your machine, verify that the set screw is still installed in a position so the mouse will click correctly.
Conclusão
131 outras pessoas executaram este guia.
Andrew Optimus Goldheart
Membro desde: 10/17/09
503.554 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 137
Autoria de 17.524 guias
12 comentários
This is a great guide. Just replaced my keyboard after a spill. It's definitely a harrowing experience, especially getting all those 67 microscopic screws holding the keyboard against the top side. But if you sit down with approximately 2 beers (wouldn't recommend more or you'll probably start making mistakes), it's a perfectly manageable 3-4 hour experience. Just take it slow!
Nathan Beach - Responder
If I replace just the keyboard, are there any steps that I can skip?
Duane Wood -
Just finished replacing the top cover assembly. The biggest problem I had was re-inserting the ZIF connectors for the keyboard and backlight. There isn’t enough room for my fat fingers to line up the cable with the socket. The angled tweezers applied carefully (don’t want to puncture or rip the cable) and a little help from a spudger made it happen. When switching the cases check carefully for “missing” parts. Besides the trackpad, the upper case I got from iFixit lacked the center support bracket for the optical drive and logic board, the little screw bracket for the bottom case and the antenna stuck to the case behind the right speaker. The antenna is a little fiddly because it’s stickied to the case and there’s not much room to pry it out without bending and possibly damaging it.
All that said, it wasn’t a particularly difficult job, just labor intensive. And the wife’s reaction to getting her business computer back without buying a new one was worth it.
Raymond Ives -
Just finished this and the only things I would add deal with the metal plate that hold the power meter button in is not mentioned and luckily I was able to slide the cable under the logic board and make the connection. otherwise it would be good to add this step before you re insert the logic board. Also the black and orange rubber part that is the bottom of the hard drive mount. They just lift out of the old case and slide into the new case. And there is a metal piece below the speaker that needs to be transferred as well.
Otherwise great guild.
maxcasas21 - Responder
I just replaced the keyboard with all those pesky screws. But all is working again. I missed the part in replacing the keyboard itself in the first place. You need to have the sheets in the right order and in the right orientation. Also does it need removal of the stiffening bar that run along the keyboard. I forgot when I removed it, so I was a bit puzzeld when to put it back. Would be nice to add those steps also to this otherwise perfect guide!
haabee - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 73
Últimos 30 dias: 318
Duração total: 172,792
