Introdução
Use this guide to replace the battery contact board.
O que você precisa
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
4 outras pessoas executaram este guia.
Um comentário
when i charge my mac it will not charge and when i plug it off it will die and now show no battery status again when I plug it back and when I leave it uncharged for a while the indicator light will still be on
And it will come on
what can be the problem?
