Ir para o conteúdo principal
MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement
O que você precisa
  1. MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement, Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement: passo 3, imagem 1 %32 MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement: passo 3, imagem 2 %32 MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement: passo 3, imagem 3 %32
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement, Battery Connector: passo 4, imagem 1 %32
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement: passo 5, imagem 1 %32
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement: passo 6, imagem 1 %32 MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement: passo 6, imagem 2 %32
    Comprar
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement: passo 7, imagem 1 %32
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement: passo 8, imagem 1 %32 MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement: passo 8, imagem 2 %32
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement, Battery Contact Board: passo 9, imagem 1 %32 MacBook Pro 13" Retina Display Early 2013 Battery Contact Board Replacement, Battery Contact Board: passo 9, imagem 2 %32
    Comprar
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
Conclusão
6 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
466.454 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 137
Autoria de 17.524 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 31
Duração total: 8,365
