Ir para o conteúdo principal
MacBook Air 13" Mid 2013 AirPort/Bluetooth Card Replacement
O que você precisa
  1. MacBook Air 13" Mid 2013 AirPort/Bluetooth Card Replacement, Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Comprar
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2013 AirPort/Bluetooth Card Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2013 AirPort/Bluetooth Card Replacement, Battery Connector: passo 3, imagem 1 %32 MacBook Air 13" Mid 2013 AirPort/Bluetooth Card Replacement, Battery Connector: passo 3, imagem 2 %32
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Mid 2013 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: passo 4, imagem 1 %32 MacBook Air 13" Mid 2013 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: passo 4, imagem 2 %32
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Mid 2013 AirPort/Bluetooth Card Replacement: passo 5, imagem 1 %32
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Mid 2013 AirPort/Bluetooth Card Replacement: passo 6, imagem 1 %32 MacBook Air 13" Mid 2013 AirPort/Bluetooth Card Replacement: passo 6, imagem 2 %32
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
Conclusão
20 outras pessoas executaram este guia.
3 comentários
My Macbook Air was bought October 2012 but has this WiFi/BT card. It failed and the machine would not boot, even to recovery or single-user mode, and removing the card allowed it to boot.
cliffordheath - Responder
Awesome instructions. Followed step by step and didn’t screw up my Air. Thanks for your assistance!
W_C - Responder
Is possible to replace this with a newer card? Be nice to have wifi-6 and Bluetooth 5.2
Jimmy James - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 84
Duração total: 28,500
