Ir para o conteúdo principal
Samsung Glyde Antenna Replacement
O que você precisa
  1. Samsung Glyde Antenna Replacement, Battery: passo 1, imagem 1 %32
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Antenna Replacement: passo 2, imagem 1 %32
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Antenna Replacement, Antenna: passo 3, imagem 1 %32 Samsung Glyde Antenna Replacement, Antenna: passo 3, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
  4. Samsung Glyde Antenna Replacement: passo 4, imagem 1 %32 Samsung Glyde Antenna Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap.
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  5. Samsung Glyde Antenna Replacement: passo 5, imagem 1 %32 Samsung Glyde Antenna Replacement: passo 5, imagem 2 %32
    • The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends.
    • Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
  6. Samsung Glyde Antenna Replacement: passo 6, imagem 1 %32 Samsung Glyde Antenna Replacement: passo 6, imagem 2 %32
    • Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
Conclusão
Cameron Law
Membro desde: 10/12/11
142 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 3-12, Regan Fall 2011 Membro de Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 1,096
