Ir para o conteúdo principal
Huawei Ascend G510 disassembly
O que você precisa
  1. Huawei Ascend G510 disassembly, Huawei ascend g510: passo 1, imagem 1 %32
    • My friend gave me it for 5€ (broken lcd and touch) so i took it apart
    • Yours may look different but tutorial like this should help you anyway :)
  2. Huawei Ascend G510 disassembly: passo 2, imagem 1 %32
    • That's back of Huawei ascend g510
    • It's Inexpensive android phone
    • To open pry left down corner
    • You don't need any tools for this... You can pry any corner to pop the back open
  3. Huawei Ascend G510 disassembly: passo 3, imagem 1 %32
    • First remove battery
  4. Huawei Ascend G510 disassembly, The battery: passo 4, imagem 1 %32 Huawei Ascend G510 disassembly, The battery: passo 4, imagem 2 %32
    • It's HB4W1H 3.7v 1750mAh (6.5Wh) Li-ion battery
    • Don't mess with Lithium ion batteries... (And don't take apart)
    • MADE IN CHINA... As everything
  5. Huawei Ascend G510 disassembly: passo 5, imagem 1 %32
    • There are
    • 7 black T5 screws
    • 1 white T5 screw
    • 1 black Philipps #0 screw
    • Just remove all and sort them so you don't mix them
  6. Huawei Ascend G510 disassembly: passo 6, imagem 1 %32
    • There are many clips along the sides
    • Don't pry to hard or you'll break some plastic
    • These clips really suck
  7. Huawei Ascend G510 disassembly: passo 7, imagem 1 %32
    • First undo all connectors (lcd, touch, camera, sim/sd slot)
    • Main PCB is hold with clips and glue
    • Really frustrating to remove it... Glue or clips are everywhere
  8. Huawei Ascend G510 disassembly, The camera: passo 8, imagem 1 %32
    • That's the camera
  9. Huawei Ascend G510 disassembly, The PCB: passo 9, imagem 1 %32 Huawei Ascend G510 disassembly, The PCB: passo 9, imagem 2 %32
    • Let's take look at pcb.
    • Unmodular and crusty... I don't like it at all
  10. Huawei Ascend G510 disassembly, The PCB (back): passo 10, imagem 1 %32 Huawei Ascend G510 disassembly, The PCB (back): passo 10, imagem 2 %32
    • As bad as front
  11. Huawei Ascend G510 disassembly: passo 11, imagem 1 %32 Huawei Ascend G510 disassembly: passo 11, imagem 2 %32
    • To separate glass (with touch) just heat it up to loosen adhesive
Conclusão
17 outras pessoas executaram este guia.
Mateusz
Membro desde: 10/20/14
1.498 Reputação
Autoria de 2 guias
3 comentários
It just won't read my sim card,i was wondering if there is a setting that has been changed?
Michael Cummins - Responder
I have a good idea of what you are doing and how much you are doing. I have a nice day ahead of the individual named recipient
Dear sir
My phone huawei G510 runs but the display light is not coming please can u give me some suggestion how to repair it
sak - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 5,656
