Ir para o conteúdo principal
How to easily fix a Xbox 360 drive that wont open.
O que você precisa
  1. How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: passo 1, imagem 1 %32 How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: passo 1, imagem 2 %32
    • First we need to take off the face plate.
  2. How to easily fix a Xbox 360 drive that wont open.: passo 2, imagem 1 %32
    • Use a paper clip or a long pick tool to manually open DVD Drive.
  3. How to easily fix a Xbox 360 drive that wont open.: passo 3, imagem 1 %32 How to easily fix a Xbox 360 drive that wont open.: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to take a rubber belt of 2 pulleys in between the hole in the DVD Tray.
  4. How to easily fix a Xbox 360 drive that wont open.: passo 4, imagem 1 %32 How to easily fix a Xbox 360 drive that wont open.: passo 4, imagem 2 %32
    • Use a damp paper towel to thoroughly clean the rubber belt.
  5. How to easily fix a Xbox 360 drive that wont open.: passo 5, imagem 1 %32
    • Use the tweezers to put the rubber belt back on the 2 pulleys we took them off of.
    • I have found it is easier to start with the big pulley first then once around the big pulley get the belt around the small belt.
  6. How to easily fix a Xbox 360 drive that wont open.: passo 6, imagem 1 %32 How to easily fix a Xbox 360 drive that wont open.: passo 6, imagem 2 %32
    • Close the DVD Drive and put the face plate back on.
    • Plug the system in and test to see if the drive works.
Conclusão
These steps have helped me fix 2 original Xbox systems and 3 Xbox 360 systems. I hope it helps yall. If you need any clarification on any of the steps please message me.
15 outras pessoas executaram este guia.
Matt Weatherly
Membro desde: 09/16/12
1.305 Reputação
Autoria de 2 guias
8 comentários
the picture of the exbox is not mine
dongwillows - Responder
the picture you show is not my console
My xbox 360 console looks like this but does not have a hole to manually open the tray.
Don - Responder
It had to use different tools to open and clean the rubber pulley with 70% Alcohol. Thank you for posting it i fixed my 2009 Black xbox 360 Console.
Gustavo Montes - Responder
How did you open your Xbox? Because mine also doesn’t have that hole
Astr0 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 113
Duração total: 11,206
