Ir para o conteúdo principal
How to Replace the Xbox 360 Optical Drive Belt
O que você precisa
  1. How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: passo 1, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: passo 1, imagem 2 %32
    • Remove the hard drive.
  2. How to Replace the Xbox 360 Optical Drive Belt: passo 2, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 2, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 2, imagem 3 %32
    • Use a pry tool to gently remove the faceplate from the Xbox.
  3. How to Replace the Xbox 360 Optical Drive Belt: passo 3, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 3, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 3, imagem 3 %32
    • Press down on the three holes as indicated to release the clips securing the base plate.
    • Remove the base plate.
    • Repeat this step on the other side.
  4. How to Replace the Xbox 360 Optical Drive Belt: passo 4, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 4, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 4, imagem 3 %32
    • Repeat the previous step to remove the top plate of the Xbox.
  5. How to Replace the Xbox 360 Optical Drive Belt: passo 5, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 5, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 5, imagem 3 %32
    • Gently unhook all four clips located on the front of the Xbox.
    • Take care not to break the plastic clips; it may be fragile.
  6. How to Replace the Xbox 360 Optical Drive Belt: passo 6, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 6, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 6, imagem 3 %32
    • Use the flathead screwdriver to gently press down on all of the indicated indents.
    • Remove the top casing from the Xbox.
  7. How to Replace the Xbox 360 Optical Drive Belt: passo 7, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 7, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 7, imagem 3 %32
    • Use the T3 Torx screwdriver to remove all six screws.
  8. How to Replace the Xbox 360 Optical Drive Belt: passo 8, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 8, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 8, imagem 3 %32
    • Carefully flip over the Xbox to the other side.
    • Lift the Xbox casing off.
  9. How to Replace the Xbox 360 Optical Drive Belt: passo 9, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 9, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 9, imagem 3 %32
    • Unplug the two connections in the rear of the disk drive.
  10. How to Replace the Xbox 360 Optical Drive Belt: passo 10, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 10, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 10, imagem 3 %32
    • Use a flat screwdriver to remove the four screws underneath the disc drive.
    • Flip over the DVD disc drive and remove the casing.
  11. How to Replace the Xbox 360 Optical Drive Belt: passo 11, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 11, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 11, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Spin the located area with the flathead screwdriver to open up the disc drive.
    • Use tweezers to remove the belt drive.
  12. How to Replace the Xbox 360 Optical Drive Belt: passo 12, imagem 1 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 12, imagem 2 %32 How to Replace the Xbox 360 Optical Drive Belt: passo 12, imagem 3 %32
    • Replace with a new drive belt.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 61
Últimos 30 dias: 305
Duração total: 3,179
