Ir para o conteúdo principal
TiVo Series 2 TCD24008A Power Supply Replacement
O que você precisa
  1. TiVo Series 2 TCD24008A Power Supply Replacement, Cover: passo 1, imagem 1 %32
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Power Supply Replacement: passo 2, imagem 1 %32
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Power Supply Replacement: passo 3, imagem 1 %32
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Power Supply Replacement, Power Supply: passo 4, imagem 1 %32
    • Locate the power supply.
  5. TiVo Series 2 TCD24008A Power Supply Replacement: passo 5, imagem 1 %32
    • Remove the belt connecting the power supply to the motherboard by pulling it out.
  6. TiVo Series 2 TCD24008A Power Supply Replacement: passo 6, imagem 1 %32
    • Remove the red, yellow, and black cable connecting the power supply to the hard drive.
  7. TiVo Series 2 TCD24008A Power Supply Replacement: passo 7, imagem 1 %32
    • Remove the two 0.31 inch T-9 screws from the power supply.
  8. TiVo Series 2 TCD24008A Power Supply Replacement: passo 8, imagem 1 %32 TiVo Series 2 TCD24008A Power Supply Replacement: passo 8, imagem 2 %32
    • Pinch the plastic plugs and lift the power supply up to detach from plugs.
    • All 4 plugs must be detached to remove power supply.
Conclusão
Phil Jones
Membro desde: 10/11/11
41 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-33, Amido Fall 2011 Membro de Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 1,210
