Ir para o conteúdo principal
How to 'repair' iPhone SE Lightning Connector
O que você precisa
  1. Ferramenta utilizada nesse passo:
    Comprar
    • Using the fine tweezers, carefully remove the build up of fluff and other debris from inside the Lightning Connector. I was really shocked how much was in there.
    • After having cleared out the inside of the Lightning Connector, carefully apply contact cleaner. It may not be a bad idea to mask off the rest of the phone before doing this. My Lightning Connector had been removed from the phone so it wasn't a problem I had to deal with.
    • Do this outside if possible as contact cleaner can stink.
    • When the contact cleaner has dried, you're ready to go.
Conclusão
4 outras pessoas executaram este guia.
Micky McGuinness
Membro desde: 09/05/15
347 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Duração total: 2,517
