Ir para o conteúdo principal
HTC Desire 510 Front and Main Cameras Replacement
O que você precisa
Vídeo de Apresentação
  1. HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: passo 1, imagem 1 %32 HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: passo 1, imagem 2 %32 HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: passo 1, imagem 3 %32
    • Switch off the phone, remove the battery and any installed SIM and memory cards.
    • Remove 7x Torx T5 screws.
  2. HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: passo 2, imagem 1 %32 HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: passo 2, imagem 2 %32 HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: passo 2, imagem 3 %32
    • Use a plastic tool to remove the rear bezel.
    • The loudspeaker is on the inner side of the rear bezel.
  3. HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: passo 3, imagem 1 %32 HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: passo 3, imagem 2 %32 HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: passo 3, imagem 3 %32
    • Disconnect the touch screen flex cable.
    • Disconnect the light sensor flex cable.
    • Unstuck the vibra-motor from the middle frame.
    • Remove the coaxial antenna cable from the middle frame.
    • The LCD display flex cable is connected to the bottom side of the board.
  4. HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: passo 4, imagem 1 %32 HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: passo 4, imagem 2 %32 HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: passo 4, imagem 3 %32
    • At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
    • Gently disconnect the LCD display flex cable.
    • Now remove the logic board.
  5. HTC Desire 510 Front and Main Cameras Replacement, Front and Main Cameras: passo 5, imagem 1 %32 HTC Desire 510 Front and Main Cameras Replacement, Front and Main Cameras: passo 5, imagem 2 %32
    • Main / Rear camera.
    • New line.
Conclusão
ZFix
Membro desde: 12/09/13
191.647 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.498 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 1,565
