Ir para o conteúdo principal
5 Tips & Tricks for HTC Desire 510
Vídeo de Apresentação
  1. 5 Tips & Tricks for HTC Desire 510, TEST MENU: passo 1, imagem 1 %32 5 Tips & Tricks for HTC Desire 510, TEST MENU: passo 1, imagem 2 %32 5 Tips & Tricks for HTC Desire 510, TEST MENU: passo 1, imagem 3 %32
    • Open the dealer app and enter this code:
    • *#3424#*#*
  2. 5 Tips & Tricks for HTC Desire 510, SAFE MODE: passo 2, imagem 1 %32 5 Tips & Tricks for HTC Desire 510, SAFE MODE: passo 2, imagem 2 %32 5 Tips & Tricks for HTC Desire 510, SAFE MODE: passo 2, imagem 3 %32
    • Open Power off menu.
    • Tab and hold Power off option until you see Reboot to safe mode menu and select Restart.
    • The phone will restarts to safe mode.
    • To turn off Safe mode, remove the battery.
  3. 5 Tips & Tricks for HTC Desire 510, DEVELOPER OPTIONS: passo 3, imagem 1 %32 5 Tips & Tricks for HTC Desire 510, DEVELOPER OPTIONS: passo 3, imagem 2 %32 5 Tips & Tricks for HTC Desire 510, DEVELOPER OPTIONS: passo 3, imagem 3 %32
    • > Settings
    • > About
    • > Software Information
    • > More
    • Tap Buld number 7 times.
    • Your Developer options menu is unlocked. In this menu you will find settings used for debugging and application development.
    • If you want to root the phone, you have to enable USB debugging from this menu.
    • Do NOT change the settings unless you know what you are doing.
  4. 5 Tips & Tricks for HTC Desire 510, INFO MENU: passo 4, imagem 1 %32 5 Tips & Tricks for HTC Desire 510, INFO MENU: passo 4, imagem 2 %32 5 Tips & Tricks for HTC Desire 510, INFO MENU: passo 4, imagem 3 %32
    • From the dealer app enter this code:
    • *#*#4636#*#*
    • Here you will find some helpful information for your device.
  5. 5 Tips & Tricks for HTC Desire 510, SNAPSHOT: passo 5, imagem 1 %32 5 Tips & Tricks for HTC Desire 510, SNAPSHOT: passo 5, imagem 2 %32
    • To make a screenshot press simultaneously:
    • Volume Down + Power or
    • Home + Powe
    • That's all.
Conclusão
8 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.647 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.498 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 1,576
