Ir para o conteúdo principal
(Fat) Xbox 360 Hard Drive Replacement
O que você precisa
  1. (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: passo 1, imagem 1 %32 (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: passo 1, imagem 2 %32 (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: passo 1, imagem 3 %32
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  2. (Fat) Xbox 360 Hard Drive Replacement, Disassembly tip: passo 2, imagem 1 %32
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  3. (Fat) Xbox 360 Hard Drive Replacement, Open the drive: passo 3, imagem 1 %32 (Fat) Xbox 360 Hard Drive Replacement, Open the drive: passo 3, imagem 2 %32 (Fat) Xbox 360 Hard Drive Replacement, Open the drive: passo 3, imagem 3 %32
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  4. (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: passo 4, imagem 1 %32 (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: passo 4, imagem 2 %32 (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: passo 4, imagem 3 %32
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
Linha de Chegada
9 outras pessoas executaram este guia.
Nick
Membro desde: 11/10/09
89.092 Reputação
Autoria de 50 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.488 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 19
Últimos 7 dias: 66
Últimos 30 dias: 265
Duração total: 9,432
