Battery Can't be Detected and Trackpad settings missing
So I recently replaced the logic board in my Early 2011 MACBOOK PRO in an attempt to breath some life back into it. Previous symptoms were the screen coming out greenish with very pixelated apple logo then crash before ever reading login screen.
New logic board fixed that problem, got the computer running but a new series of issues has arisen:
1) originally the battery emblem had the grey X in it, and the power cord light is stuck green even though battery is not charged. Tried resetting NRAM/PRAM and the SMC, instead of fixing the issue the battery icon has disappear entirely. I also have tried running Coconut Battery which also does not detect the battery. Put a multimeter on the battery connection to the logic board and I am getting 3-12 volts on various pins (first thought was the DC in had gone bad).
2) Running High Sierra the settings menu Trackpad section does not detect the internal trackpad even though it is working. Instead it is stuck looking for a bluetooth magic pad. Trackpad works fine accept I can't change any settings and it does not recognize Right-Click. All other gestures work.
My question is, could this all be from a bad battery? Its like the computer thinks it is a desktop now the way the battery icon has vanished and it is looking for a magic pad. Im trying to avoid a 60-100 dollar battery unless I am sure it is the battery and not a module on the logic board, SMC, etc. Any recommendation are greatly appreciated for further testing or a definitive on what the issue is.
UPDATE: New battery has not fixed the issue. Battery is still not being detected by system settings or coconut battery. However, the logic board is drawing power as disconnecting the charger does not cause instant shutdown. System settings is still not recognizing the trackpad either.
I’ve reinstalled OS High Sierra from disk recovery to no avail. At this point I’m running out of options other than possibly a faulty logic board. I’m hesitant to call it that since the battery is providing power and the terminals on the logic board read 12v which would seem correct for a 10v battery.
Any other ideas on tests to run or hard resets are much appreciated. Only other hardware step that involes power is the MagSafe itself, which I may try to sneakily test one at a local Apple store before purchasing a new module. I’ll attempt to call iFIXIT regarding the logic board they sent me and see if they recommend trying another.
To recap: SMC and PRAM reset have not helped, reinstalling OD has not changed anything, Single User Mode fsck -fy has not repaired anything, replacing battery has only changed that the computer appears to be drawing power from the battery though not detecting it.
Update (12/05/2017)
to be more specific, the battery icon will not appear. every time i change the setting to show battery percentage it resets the box to unchecked after a brief pause.
I've also tried reseating the RAM cards and the battery twice.
Esta é uma boa pergunta?
9 comentários
I have this exact same problem. Running the latest Mac OS update (10.13.4) on a Macbook Pro Early 2011. Have reset SMC, PRAM, and just did a clean install on the OS. Not batt icon, no trackpad or mouse settings available but the trackpad works. Coconut battery does not see the battery either.
por tim24frames
I feel like it has to be a very deep software issue with Mac OS. Nobody between here or Apple seems to have a solution or answer. Apple just admits they "know of an issue" but don't seem to be doing anything to try and fix it.
por Gabriel Conlon
Exact same problem happened yesterday with my Macbook Pro mid 2012 model. It does not show the battery - if I disconnect the charger - it switches off - and I do not see the trackpad settings - just searching for a bluetooth trackpad - even though the trackpad is working though I cannot change any settings on it!!! Very exasperating - I think it came up after I upgraded to the latest High Sierra update - but dont know if there is a direct link!
Someone - knows how to fix? Of course, it could be a bad logic board.
por Manu Srivastava
And the problem has been resolved. I somehow suspect that it was an issue with one of the recent High Sierra updates. I did an update on Friday 20 Jul2018 and the problem came up the next day. Today (30 Jul) got another update which I did and since then the computer is behaving perfectly normal!! Hope it lasts!
por Manu Srivastava
Did anybody figure out this issue?
por Iara Valsecia
Exibir mais 4 comentários
