Ir para o conteúdo principal
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 Perguntas Visualizar todos
MBP extremely slow after SSD Upgrade. What's wrong with my mac?
I have a MPB 15" 2.53 mid 2009. I upgraded the standard hard drive to a SSD (512 GB Sandisk X210) purchased from ifixit.
I cloned the factory drive to the SSD using Super Duper. After cloning the HDD to the SSD I installed it and turned it on, it booted up fine but not quite as quickly as I would expect for an SSD.
Verified and reparied disk permissions.
Restert. Boot up time about 1 minute 20 seconds.
Shut down.
Reset PRAM
Boot up about 1 minute.
Restart. Boot up time about 43 minutes.
I have no idea what happened in the middle there but something is obviously not working right. Now when I click on applications they go gray then take several minutes before launching. I'm not sure what to do. Please help!
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Hi, I did upgrade my MBP mid-2011 with an SSD 1T in the disk slot and kept the old HDD (500G with possibility to boot on it) in the optical drive space.
All went well.
After 1 month using it and booting on SSD, my MBP started to be slower and slower to boot on SSD.
I did follow the above recommendation, went in _system_pref_ Startup and found out that the HDD although greed out, was there and in first position.
I did select the SSD and clicked _restart_. ..... waited for a couple of minutes with the black screen and turning thing, and decided to power off with the power button. Then applied a "normal" restart wit the power button. (NO PRVM reset)
and ........ TADAaaa. all is fine again and fast boot on SSD.
Verified in startup, only SSD is now visible, which is ok.
Good luck.
por
Adicionar um comentário
7 respostas
Solução escolhida
The internet had the answer for me. Apparently your startup disk setting is pointing to a disk that's no longer in your system. I'm guessing the OS can't find it and is waiting for it to spin up. It doesn't try the new SSD until a timeout occurs.
Go to system preferences and set your Startup Disk setting to be the new disk and I'll bet that changes everything. It did for me.
Esta resposta foi útil?
Pontuação 13
9 comentários:
Good catch!!
por
It also works for me. I had before for the long time just the white screen before apple logo comes on.
por
It worked perfectly!
I had the same problem when I upgraded my original 128GB SSD with one of 256GB from Transcend. I couldn't understand why the new SSD had added 10s of grey screen on startup before the Apple logo appears.
So I follow these steps and all started working perfectly again:
1. Go to System Preferences -> Startup Disk
2. Click on the bottom left Lock tu unlock the changes
3. Select Macintosh HD (it's likely to be the only on the list)
4. Click 'Restart...'
You're done!
por
Thank you so much! Its working!!
por
Thanks!!! Worked for me!!!
por
Exibir mais 4 comentários
Solved!! - I had almost exactly the same symptoms with my 2011 MacBook Pro. SSD upgrade Super fast for a month, then suddenly became slower than ever. Symptoms included unable to keep up with keystrokes (really annoying), slow application loads, slow printing.
I tried just about everything suggested on the internet; Reset PRAM, SMC, the wear levelling (TRIM). Reinstalled a clean OS (Lion, Yosemite, and El Capitan). Nothing made the slightest difference. I bought a different drive (i had a samsung EVO) I read the OWC were great...no change.
Then one day the mac failed to find my hard drive. I was pretty ticked off by now. So my research for this problem went down a different road. And I ended up buying a replacement SATA cable MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable Fixed it completely - Mystery solved.
So if this post helps just one person avoid six months of torture I will be delighted.
Imagem de MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable
Produto
$29.99
Pontuação 5
6 comentários:
Man, you've just saved my brain. I was suffering of the same issue during the last month. I've tried almost everything you've tried, but only cable replacement helped.
por
I had the same problem. Replaced 3(!!!) SATA cables. No joy at all. Ended up with installing back an old good HDD. My old MacBook Pro 13" Late 2011, works fine again.
por
@ Rob Fox-- so installing the new SATA cable was only a temporary fix? I'm assuming that's why you went through three of them? Also, what type off SSD were you using?
por
Give this a read! Your Hard Drive Cable Is A Ticking Time Bomb Also keep in mind the OP's question is for a different model! The older 2009 & 2010 can encounter different issues! often times people put in too fast a drive for the slower SATA II interface these older systems have. Review your drives spec sheet it needs to state clearly it supports SATA II I/O data rate as an example [https://www.samsung.com/semiconductor/gl...|Samsung 860 EVO SSD) Vs [https://documents.westerndigital.com/con...| Western Digital Blue SSD which is a fixed SATA III (6.0 Gb/s) drive and won't work properly in the older SATA II (3.0 Gb/s) system's!
por
I was going CRAZY!! Everything was lagging.. every two clicks the spinning wheel.. Tried all the software stuff (resets, formats, reboot, reinstall)... was about to give up then I read this comment! Thank you @davehartley !!
I took my Mac Mini 2012 apart, and the Hard Drive Cable (or better, SSD drive cable) was full of dust between the pins.. took a needle to clean all the dust in between, gave it some good blows, put it all back together, and SWOOOSH, my 2012 Mini is back to its amazing speed, 9 years in.. WONDERFUL!!!
por
Exibir mais 1 comentário
the hard drive name has nothing to do with it. You can name it whatever you want as long as you select it in the system preferences control panel as the startup disk.
Pontuação 1
How do you set it to the new SSD? It still only has the Mac HD listed.
Pontuação 0
6 comentários:
Press the Option key when you start you system. You'll be greeted with the Disk Manager which will allow you to select the boot disk. Once you system is up and running go over to your System Preferences, there you'll find the Startup Disk control panel, open it and select the drive and you're done. If you can't see the disk its not prepped correctly and/or is missing the OS. You'll need to redo the drive setup and re-install the OS from the installer app.
por
It's also worth noting that if you clone the old hard disk onto the SSD, you'll retain the name "Macintosh HD" for the SSD. This is not sufficient to automatically boot from the SSD. (Somebody correct me if I'm wrong, but the boot loader works with physical disk IDs, and not the name, since it has to boot before the file system is loaded.) You'll need to set the boot disk to "Macintosh HD" once again to register the new disk.
por
Good point! @EBarnhart001 Another reason not to use cloning software as it just confuses things.
I know old habits are hard to shake, cloning is one of them! I have had more problems with cloning software than I can shake a stick at. Apples Migration Assistant or TimeMachine backup is the only real way to do it.
por
I don't remember if I cloned or restored the system disk image from a backup onto the SSD. Probably the latter since I used no special software. Anything that saves the hassle of reinstalling the system is a good idea IMO. The user just needs to unset and reset the startup disk setting, even if it looks correct in the control panel.
por
@EBarnhart001 not true. It doesn't have to be called Macintosh HD at all. That's simply the name Apple gives it by default. I rename all my HD and SSD to MacOS HD and it won't affect a thing. All apps will see it etc. The name can literally be anything. He'll you could name it floppy disk for all the Mac is cares. Just be sure it's set to the default startup disk in system prefs and it'll boot fine. This issue 8s definitely the sata cable. even after a successful clone you can go in and rename the same hard drive you just clone to whatever you want and the system will still boot just fine. It's all about the Sabbath bus and has nothing to do with the actual name that you give the drive. try it out, rename your hard drive and reboot your machine and it'll boot up just as fast and everything will retain its symbolic links etc you won't have a single issue
por
Here is what worked for me. I did a SuperDuper clone from a 256GB Samsung EVO 840 SSD to a 1TB Samsung 860EVO. After doing this the MacBook booted up ok but I noticed that there was a click delay on every action and everything seems to have somehow slowed down. Almost like the hardware know that the SSD has been removed and was trying to verify every file that was being opened.
BlackMagic disk speeds didn’t reveal anything out of the ordinary. I tried to update the Samsung SSD firmware and it was already updated. I ran disk utility and did first aid. None of these solved my problem.
Finally, I booted the mac into recovery (cmr+r) and did an OS reinstall. This fixed my problem. You don’t loose any of your files or applications. It simply does a reinstall.
Hope this helps.
Pontuação 0
Same issue, different results. Help, never have I seen this in 15 years…
2010 MacBook Pro, 2.4ghz C2D, 8 gig ram, (320 original rotational drive) 240 ADATA SSD upgrade attempted, but failed.
The ADATA 240 or 480 SATA III is what I use on all my rebuilds, never an issue.. I just put one in a 2008 MacBook and it is lightning fast, as expected.
But, this 2010 is about to cause me to lose my last 5 hairs. I formatted it, as normal, and ready to build via my USB with High Sierra natively supported. It goes through the normal steps (language, disk utility, etc.) Then it starts the build to the SSD. It starts to calculate the time to install, 9 minutes, then 45 minutes, then 1 hour 53 minutes, come back in about a half hour it says 7 hours, 23 minutes. WHATTT? Bad comm to the drive = bad cable. But, wait, it works fast and fine on the rotational drive. I order another cable to rule it out. Same exact results, but 9 hours to build a 34 minute system drive. So, I assume I got a bad SSD (although it formats fine in my 2019 MBP). Have them replace the SSD. Now I have my new cable, new SSD, ready to go. NOPE. 9 hours 54 minutes. So, I go to bed, let it build. It’s all built. Everytime I click the mouse - color wheel. I select the SSD as the startup disk, restart. It doesn’t care, still unusable. I put the original back in, fast as normal (not fast ssd though), and sellable to a needy client.
I search, starting here, and find this thread among others. I read to line the cage where the SSD fits with nylon electrical tape to help insulate the drive cable from shorting. I do that, all the way to the connector on the logic board it is not touching any aluminum. I format the drive, and rebuild. 9 hours again. Now, after 15 years of seeing almost everything, I’m completely stumped and really tired of searching for hours and hours to no avail.
I don’t like to post, I like to read so I don’t have to post. Or, post in support if I know the answer or have been through it. I’M POSTING…LOL. This one has me stumped. The only model I’ve seen that just doesn’t fly across the table in happiness with an SSD.
Could it be the SATA II vs. SATA III issue? Where can I even find a SATA II SSD? Is it a firmware issue? As I said 10.13 was installed, and has the firmware for SSD and for APFS drive settings. Bad firmware write? Where do I find just the firmware to write? The wider drive cable needed that’s for 2012 on a 2010? I’m ready for your smart ideas. Sorry, if I should have started a new topic, but this one existed with the same description. And sorry for long post, and thanks in advance for any suggestions that you don’t see here.
Pontuação 0
1 comentário:
i have exactly the same issue on a 2012 macbook pro. the strange thing is if i install windows 10 to the mashine it just works fine if i use macos or linux it is extremely slow with the SSD
por
Your issue might be that you need to turn on Trim through terminal then reboot
Pontuação 0
1 comentário:
Thanks, I tried that command, and it said unrecognized command. Maybe I had the wrong command. Do you happen to know it? Is it this: fsck -fy in single user mode? Or, maybe it's something about the 6gig speed it doesn't like on those drives? Still mulling over it. I may try a different drive, altogether from a different manufacturer. Although, it sure did work great in a Macbook (non-pro) mid-- 2008 C2D.
por
Adicionar a sua resposta
briandholley será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 30
Últimos 30 dias: 98
Duração total: 86,143
